Home > General Chat > checking if my engine is a turbo
Dolly
Member #: 9061
Louth
right well basically i was told the other day that my engine that i have for sale is a metro turbo engine but i dont know how i would go about checking if this is true is there any marks i should be looking out for to identify it anyway heres the link
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...=STRK:MESELX:IT
cheers for any help
it has nno engine number either
Edited by Dolly on 12th Nov, 2010.
there's only a few ways to tell, none of which are evident in your add.
As it's a 1330, it won't have the turbo pistons, so it makes no odds whether it was or wasn't, as the rest is pretty much the same as any metro engine.
Dolly
Member #: 9061
Louth
ok then thanks for that
turbominivanman
Member #: 1504
Westbury, Wiltshire
It could be worth a few checks:
1. Is there a capital 'T' stamped on the top pface of the cylinder head in one of the corners ?
2. If you were to take the rocker cover off, you may be able to squint through to see the valves under the rocker pads.
The exhuast valves have a larger diameter stem than the inlet valves. Clearly you're not going to go diving in with a micrometer, but do the exhaust stems look visually bigger than the inlets ?
3. What is the engine serial number off the plate rivetted on the block ? It should start 12............ Someone on here can probably advise if it matches that for a Metro Turbo.
4. What is the distributor serial number off the side of the dizzy ?
Shame yours didnt sell. It probably would if you were able to confirm the answers to the 4 points above relate to a Metro Turbo.
Richard.
Edited by turbominivanman on 14th Nov, 2010.
