Home > Help Needed / General Tech Chat > Damm, mine thrust are f.cked
paneermeel
Member #: 1404
The Netherlands
mine engine stopped when i pressed the clutch *angry*
And after reading some info on this site i suspected mine thrusts.
And now i know for sure that they are the problem.
I feel there is some material still on the crank so now i come to you. I read that if youre crank is not perfectly smooth (feeling with youre fingertips) get it to a workshop to get it a regrind. But how does this work? Do i give them mine crank to get it regrinded or must i give them the complete block?
I'm also thinking of the possibility to get some wet sandingpaper and try to get the crank clean.
Any info would be appreciated
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
Take the crank out of the engine. You will know if your thrusts are damaged, they will look like this
You will need to get the thrust face ground and fit oversized thrusts
pinkyandnobrain
Member #: 2588
Pretoria South Africa
It really depends on how bad the damage is. Maybe you could post a pic of the damage ?
"Try to take over the world!"
Bah, those are like new...
I saw worse than that recently. They had dug a 1/8" groove into the cap.
I believe that wolfie couldn't find his when he stripped his down.
paneermeel
Member #: 1404
The Netherlands
This is what i found when i went searching for my little problem*oh well*
The rests of the trusts are on the crank and in the sump of the gearbox*tongue*
Edited by paneermeel on 14th Nov, 2010.
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
And the crank:
www.turbomini.nl
Johnny
Member #: 6926
Accrington
wow
Yep, theres your problem :)
LMFAO, Wet 'N' Dry *Rofl!*
sorry!
The crank will deffo need to go to the machine shop. Block possibly. I say the block might need to go to the machine shop, as you will have to check the roundness of the center bearing housing (block/ cap) as any excessive heat from the thrusts can distort the center bearing housing. Also, if the thrusts have spun, the facing on the block/ cap needs checking that it is perpendicular to the bearing housing/ crank journal.
Secondly, you need to find out why this happend in the first place. What clutch do you use and has it been assembled with the correct lug hights?
paneermeel
Member #: 1404
The Netherlands
ok, block will go to a machine shop.
And since everything is open i will make some more mods.
Like Carls mod on the thrusts*happy*
The problem is most likely, old thrust with grey clutchcover. I've red some more people had problems with it.
www.turbomini.nl
how many miles had the engine done?
Fucking grey clutches!
Time to go verto?
paneermeel
Member #: 1404
The Netherlands
2 meter:)
It was the first drive since the rebuild.*tongue*
Now i can hit myself, the engine dropped in revs but i tried the clutch one more time and then i heard a noise that said: This is going to cost you some more money.
Looking at the damage on the crank and thrust i'm starting to believe they were put in the wrong way. Not by me, but i should have checked it, dammmm. A hard lesson.
www.turbomini.nl
ouch!
what does the back of the thrusts look like, can you see any copper material left?
What was the crankshaft endfloat when built?
bosroamer
Member #: 1981
the Netherlands
Damn,
those thrusts look pretty fooked.
Oilgrooves must be facing outwards, my endfloat is what Haynes quotes.
What is the optimal endfloat when going turbo?
(sorry for hyjacking the thread)
On 8th Aug, 2010 Brett said:
Carl worked my bottom end, cannot fault the workmanship its spot on, a good old chinwag too :)
The same as when going N/A :)
paneermeel
Member #: 1404
The Netherlands
The other side has some copper left but the most of it has gone.
I can not remember the exact endfloat i got. But i do remember it was right between the min en max the Haynes said. I was, at that moment pretty pleased because i did not have any other thrust at hand when we put the engine together.
www.turbomini.nl
the back does not have any copper on it to start with. I assume the thrusts have spun especially if you found one half in the sump?
This is too much in my book. Aim for the lowest, ie. 2 thou.
paneermeel
Member #: 1404
The Netherlands
The parts were still in place but the part that is missing lies in the sump, in pieces.
And one side of the trust is completely broken (see photo) the other side is the side with the grooves. The grooves are now filled with material. When i removed the bearing cap the trust fell out so am not sure how it was mounted. But one side of the trust is worn en so is the crank. This would mean that the trust were mounted the wrong way.
And what Vegard says with to much endfloat:$
www.turbomini.nl
0.005" thrust is fine
Van's were quite loose IIRC around 5thou
I don't agree.. This is too much. If however going this loose, the bearings should be ground flat. If installing brand new ones this loos, they'll open up at least one thou after the first 18 revolutions. The brand new ones are far from flat.
