Home > Help Needed / General Tech Chat > brake switch on dash... test??
sparkle
Member #: 5544
i'm sure i've read about this on here before but used the search and found no mention of it. the switch on the dash with the brake symbol on it, am i right in thinking it is for checking the brake light circuit? thanks for any info.
It checks that the warning light (the switch itself) is still functioning. There is a float in the brake master cylinder cap. The light should come on if the cap is removed. If it does not, there is a problem with the float switch or wiring. The test switch only tets the light. Most of the time the wiring at the float or the float itself is faulty, yet the light still works when you push the switch. Totally useless as far as I can see. Nobody uses the test switch and if you did, what is it telling you?
This is not normally a question asked on this forum, but im sure it gets asked at least once a week over on TMF
Do you need one for the MOT?
no, mine failed on this years ago, i took haynes to the garage, he traced the wiring diagram and was rather embarrassed when he found out what it was for lol
Good stuff. So do I still need the warning light?
Just had a look here:
http://www.motuk.co.uk/manual/contents.htm
and found no mention of warning lights for the braking system. So I'd say not.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Technically you do need one, modern vehicles use the handrake warning light for this. The handbrake tests the bulb every time you put the handrake on, and if it stays lit its indicating a fault, usually low fluid due to what ever reason.
Alex1340
Member #: 111
Loughborough
Ditched that years ago. Moved the fog light switch across from that little tacked on panel on right hand side. Much neater
madcatminis
Member #: 5327
Dudley, West mids
My mate had it wired up to his boost switch. Very discreet. *happy*
I took the spring out of mine and it now operates the interior light.
My mate once wired the switch through the starter relay circuit, so you had to hold it down while turning the key to start the car; a rather clever 'hidden' switch for security.
george91
Member #: 8932
i was planning on not wiring this in, thanks for the info.
