| Home > Wanted > Flywheel locking tool | |||||||
17th Nov, 2010 at 09:17:04pm
I know you can use allsorts but I am looking for the tool rather than wedging a screwdriver in the ring gear.
17th Nov, 2010 at 09:23:35pm
I always use an old big-end shell although i do wonder how easy it wouls be to make up the correct tool........... |
17th Nov, 2010 at 09:38:18pm
Cant beat a big end shell! |
17th Nov, 2010 at 09:42:21pm
I prefer a mains shell If something is worth doing, it's worth doing half of. |
17th Nov, 2010 at 09:45:31pm
something like this,
17th Nov, 2010 at 09:48:11pm
+1 for the shell, dont bother paying for the tool. |
17th Nov, 2010 at 09:49:05pm
Al of the above are rubbish, you need a section of ringear,6-7 teath and perfect engagement , spreads the load over multiple teath,
17th Nov, 2010 at 09:52:44pm
cool do i just jam it in there lol I have started posting on Instagram also my name on there is turbomk1golf
17th Nov, 2010 at 11:32:12pm
I have the one pictured above and it has served well, certainly not had any issues with it, other than the initial cost.
18th Nov, 2010 at 08:42:46am
I've been using a knackered old 9/16 socket for years. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Nov, 2010 at 11:26:06am
Just a thought. People suggest using a bearing shell to those who are asking the question on how to lock the flywheel to remove it. Those people clearly won't have a random bearing shell lieing around as they've never had an engine apart, which is the main reason they're asking the initial question to start with On 26th Oct, 2004 TurboDave16v said:
18th Nov, 2010 at 12:38:17pm
I use a Metro front engine mount.... And I think mine is a better idea than anyone elses too. On 17th Nov, 2014 Tom Fenton said:
18th Nov, 2010 at 12:40:53pm
I use the patented Carl Austin ring gear tool, as you would expect from Mr Austin it is faultless.
18th Nov, 2010 at 01:49:28pm
On 18th Nov, 2010 Tom Fenton said:
I use the patented Carl Austin ring gear tool, as you would expect from Mr Austin it is faultless. I don't see it on the website Can I get it in Titanium too?
18th Nov, 2010 at 01:59:40pm
I use the patented Carl Austin ring New signature
19th Nov, 2010 at 07:52:17am
the reason i use a piece of ringear, is because i have broken a tooth off beofre using ill fitting silly pieces of steel jammed into the 6-7mm wide gear i always use,, the 25mm piece of eingear is a perfect mesh and spreads tha load over 2-3 teeth,
![]() 296 Posts Member #: 9117 Senior Member Northampton |
19th Nov, 2010 at 12:11:41pm
Where's the best place to get a Austin ring gear style tool from ? The one in the photo only locks one tooth eek Edited by boostjunkie on 19th Nov, 2010. Confessed addiction to everything mini |
19th Nov, 2010 at 12:29:23pm
From the man above your post If something is worth doing, it's worth doing half of. |
19th Nov, 2010 at 11:24:57pm
On 19th Nov, 2010 boostjunkie said:
Where's the best place to get a Austin ring gear style tool from ? The one in the photo only locks one tooth eek It's "an" Austin, not a Austin carl |
13th Feb, 2011 at 12:45:01am
On 17th Nov, 2010 fastcarl said:
Al of the above are rubbish, you need a section of ringear,6-7 teath and perfect engagement , spreads the load over multiple teath Well thanks to carl for a piece of his ring, I have just got around to playing with it. Anyway this is what i have come up with I know the weld is a bit agricultural i am still getting to grips with my £50 welder.
thanks simon. I have started posting on Instagram also my name on there is turbomk1golf
15th Feb, 2011 at 10:36:39am
sweet..... On 21st Jan, 2011 fastcarl said:
15th Feb, 2011 at 06:23:06pm
We used some 1.75" exhaust the other day, cut down the middle into a crescent, then hammered a tiny bit so that it fitted between two teeth rather than one, as we didnt have a shell bearing to hand On 26th Jan, 2012 Tom Fenton said:
15th Feb, 2011 at 06:35:33pm
Edited by Rob Gavin on 15th Feb, 2011. |
while the fancy one pictured above needs the starter removing but not the wok, which is much better if you are working on the front end of the engine. Dropping a bearing shell into the clutch housing will only create hours more work.
