| Home > Help Needed / General Tech Chat > mainshaft nut | |||||||
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
25th Nov, 2010 at 07:52:20pm
Did a rebuild on my gearbox today.
25th Nov, 2010 at 10:07:06pm
the shaft you had is an ...... A series,
25th Nov, 2010 at 10:38:51pm
but if they are identical shafts the nut should fit??!!
26th Nov, 2010 at 01:10:32am
On 25th Nov, 2010 clubbie70 said:
a series shaft has a smaller bearing end to fit the 1st motion shaft. if i am correct There was a short period of time (79-81 according to Minispares catalogue) just before the changeover from A to Aplus when the 18mm nose was used on early (A) geartrains. So measuring the small bearing end does not tell you A or Aplus. Perhaps the change to a metric nut was not made until the end of this 2 years ??? Schrödinger's cat - so which one am I ??? |
26th Nov, 2010 at 08:36:59am
just found out that the nut from the 1st motion shaft fits the thread of the third motion shaft.( its way bigger)
26th Nov, 2010 at 11:19:55am
From your description "just found out that the nut from the 1st motion shaft fits the thread of the third motion shaft", then this one.
26th Nov, 2010 at 12:14:49pm
I can also confirm that there are 18mm shafts with both sizes. On 13th Jul, 2012 Ben H said:
26th Nov, 2010 at 05:05:45pm
I dont suppose anyone has a 14mm nosed shaft with a large nut? On 28th Aug, 2011 Kean said:
