Home > Help Needed / General Tech Chat > Turbo oil feed for GT17
Billus89
Member #: 8931
Hi people. Just a quick question. Will the minispares turbo oil feed hose in the link below fit on the GT17. I ask this because its obviously suited for the T3. Any help would be much appreciated :)
http://minispares.com/Product.aspx?ty=pb&pid=36279&title=
im certain the thread is different ( obviously turbo side *wink* )
you might get away with just changing the bolt and not the union on the end of the hose. You local hose place will be able to swap the end for not a lot of money
jamestar
Member #: 9159
Devon
i was thinking about this for my GT1752, the hose is expensive for what it is!!
Got some info which be of some help to you:
Turbocharger model GT1752LS, SAAB part# 5955703, Garrett part# 452204-0005.
Oil inlet thread M12 x 1.5-6H
Oil outlet bolt holes M6 x 1.00-6H, center drain hole 12.80mm
Water in/out threads M14 x 1.5-6H
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
http://cgi.ebay.co.uk/M12x1-5mm-Banjo-Turb...e#ht_1514wt_952
What about this?
Edited by Gaball on 28th Nov, 2010.
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
I've either made them from bits
I bought from here http://www.speedflowshop.co.uk/index.asp or just bought a T3 one and converted one end.
