Home > For Sale > 1430 engine, splitting
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
decided to split the engine, all needs to be gone asap so open to offers on prices, new car arrives soon so garage space needed.
Recently rebuilt webber
5" swanneck manifold with servo take off
Drilled and tapped with fittings for megajolt vaccum
Pipercross foam filter
Adjustable fuel pressure regulator
£180ono
Straight cut gearbox
4 pin diff 3.4 FD 300 miles old
Centre oil pipeup
Straight cut drops
£650ono
Billit ultralight flywheel
Billit backplate
Clutch plate
Grey cover
£250ono
Stage 5 head
37mm
31mm
Bronze valave guides
Double valve springs
11 stud
Ports are massive, matched to exhaust gasket
£350ono
1.5 roller rockers (red)
<300 miles old
£150ono
Megajolt unit (brand new)
EDIS module
Coilpack
VR sensor
Pulley with trigger wheel fitted
Mondeo HT leads
Engine mount with mount welded on for VR
Shielded wire
Vaccum hose
Basically all is new apart form FORD donor parts
£220ono
A+ block bored 73.5mm
Drilled 11 stud
286 cam
Beltdrive timing gear
Reground and stroked crank
73.5mm powermax pistons ?
New oil pump etc fitted
£450ono?
Facet red top pump (<300 miles old)
£45ono
will add more to this post as i sort through it, will put up pics asap
open to offers, like i said taking up space of new car
gaz - 07767084034
Bodge Job
Member #: 953
London
PM'ed Megajolt
boz-reb-2303
Member #: 2301
Blackpool , Lancashire
PM'ed
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
http://s609.photobucket.com/albums/tt176/boz-reb/
1971 turbo mini van
1978 clubman estate
1971 clubman
Turbo_Jonesy
Member #: 9041
PM'ed
the_soon_to_be
Member #: 1600
megajolt sold, sorry to everyone else that was intrested in it
gaz
Bodge Job
Member #: 953
London
Bull S***
Edited by Bodge Job on 27th Nov, 2010.
adcyork
Member #: 6807
York
pm'ed
Steve A
Member #: 7876
Walsall West Midlands WS1 2DW
pm'd, interested in gearbox, drops and maybe other stuff, cheers Steve
Patina=old and knackered and won't clean up
mikko
Member #: 5393
Belfast
still got the pistons matey?
Cables
Member #: 9270
is the crank available and the box without drops and diff?
pot_dan
Member #: 326
bradford, west yorks
Pm sent for drops and diff.
http://turbominis.co.uk/car/105/
PaulH
Member #: 2340
Dublin Ireland
Is the cylinder head still available ?
On 17th Feb, 2009 Rob H said:
marco.h
Member #: 8888
worcestershire
i'll have the head on the off chance youve still got it
almichie
Member #: 2065
If the gearbox isn't gone I'll take it, pm with payment details.
Al
Shaft seems nice and snug
the_soon_to_be
Member #: 1600
bit of a thread bump, all stuff is sold
