Home > Help Needed / General Tech Chat > MED 1.5 roller rockers
SumpNut
Member #: 28
I have built my engine, all is well apart from my rocker cover not fitting over my new rockers!
I have the aluminum flat top thing, does anyone use these rockers, If so what rocker covers are you using?
how much is the rockers touching the cover, it is common to have to grind the rocker cover in places
1310turbo
Member #: 41
hmm thats strange, i thought that the flat top taller rocker covers were meant to get over the problem of the 1.5 rockers, as i believed the standard metro rocker did catch in places
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
SumpNut
Member #: 28
I have ordered a new cover from mini spares that is designed to not catch *oh well*
1310turbo
Member #: 41
could you post a picture of it mate when it arrives, be interested to see what it looks like
Users viewing this thread: none. (+ 2 Guests)
