Home > Introduce Yourself > How to change boost on a Garrett T3
tojar
Member #: 9140
I have a 1275 A engine with a T3 turbo. When I purchased the car, the previous owner said the boost was set at 8lbs. I want to reduce that to 6lbs, how do I do that?
Rick.SPI
Member #: 8027
http://turbo-mini.com/9656.html
read this mate.
i would advise having a good read through the whole site as it will answer 95% of what you probably need to know, thats where i started as its a brilliant website.
tojar
Member #: 9140
That's a lot to read, how can I go directly to that subject
boz-reb-2303
Member #: 2301
Blackpool , Lancashire
Roam wasn't built in a day, Phill Knows his sh#t, read the lot.
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
http://s609.photobucket.com/albums/tt176/boz-reb/
1971 turbo mini van
1978 clubman estate
1971 clubman
It took them a fair while to build Rome too.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
They did build the aqueduct.....
On 19th Jan, 2010 wil_h said:
Johnny
Member #: 6926
Accrington
That link takes you directly to the "changing boost" bit which has about 1min worth of reading. soo not that much?
tojar
Member #: 9140
Thanks, good info. I think I will stick with 8lbs for the meantime until I get to know this system better.
and they brought piggies...
where you from tojar?
tojar
Member #: 9140
I'm in the US joey in the state of Tennessee
tojar
Member #: 9140
i saw a pic of a boost control unit at this url
http://s609.photobucket.com/albums/tt176/b...pictures058.jpg
What, actually does this do? Where can I get one and how do I attach it to the turbo? Can I use it to reduce the boost?
turbominij
Member #: 2104
Essex - UK
google my friend!
http://lmgtfy.com/?q=in+car+boost+controller
6th one down has full instructions and is exactly the one you posted a picture of :)
a bost controller like this bleads off the excess pressure fooling the turbo to think it hitting 8psi when it is hitting 12-15psi
if you are adding more boost you NEED to add more fuel so dont just turn that shiney nob!
Edited by turbominij on 6th Dec, 2010.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
wintersurferuk
Member #: 2208
ive seen that one jump from 10psi to 20psi, might want to fit a simple one mate.
Yep we had serious problem with the ball and spring kind. Cost us the vans first engine IMO
turbominij
Member #: 2104
Essex - UK
i was using one of these bleed valve but ended up ditching it as it was iritic boosting at different levels, that was according to each of the guys i had tune the car so ended up going for an electronic jobby like the jap guys go for and now have totally stable boost and have never looked back.
2 stage at the push of a button go from 6psi to 13psi there is no guess work as to what boost its running you set it and leave it and just use the button to switch between them.
now for the downside there not cheep i paid £100 for mine alot of people will say its a waist of money but im more than happy with mine.
Whatever you use it WILL NOT be able to reduce the boost from the rating of the actuator.
To reduce the boost lower than the actuator setting is not possible (well it is, but it would be pointlessly complicated). You need something like the standard metro turbo actuator (4.5psi) and then work up from that to your 6psi.
Luckily it only cost me a head gasket! Steer clear!
