| Home > Technical Chat > would this be a good system? | |||||||
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
2nd Dec, 2010 at 11:44:15pm
was talking and thinking of way to mount my 2056 and was thinking of this over the standard setup, reasoning on this:
Edited by Rick.SPI on 2nd Dec, 2010. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
2nd Dec, 2010 at 11:56:13pm
On 2nd Dec, 2010 Rick.SPI said:
can anyone see anything that will be a nusience/ you wont be able to see anything will be the biggest nusience
seriously though DON, Matty's mini, im sure there is more too Edited by Brett on 2nd Dec, 2010. Yes i moved to the darkside |
3rd Dec, 2010 at 12:10:39am
similar to mine, except mine has the compressor exit going over the rad,
1083 Posts Member #: 8932 Post Whore |
3rd Dec, 2010 at 12:18:24am
Rick do you mean have the exhaust coming out of the front end? if so i think its going to be to be too loud with the exhaust that short. sorry if i got the wrong idea |
3rd Dec, 2010 at 07:23:50am
Yes exhaust straight out the side but with a silencer noise isn't a big problem itl be a very weekend car anyway. Extra benefit being ground clearance with a 3inch exhaust that was planned. Is there any cons on performance with this setup. I don't think it will be sitting as high as the dons so shouldn't be a massive sight issue. Mine can't be as low as yours Joe as mines still 5 post and will be running the hif, I'm liking your setup tho. On 17th Feb, 2011 apbellamy said:
3rd Dec, 2010 at 07:33:14am
doesn't the exhaust have to come out behind the driver for the MOT? On 11th Feb, 2015 robert said:
3rd Dec, 2010 at 09:22:05am
3rd Dec, 2010 at 09:43:17am
I
On 3rd Dec, 2010 apbellamy said:
doesn't the exhaust have to come out behind the driver for the MOT? this is what i was told by my mot tester but i got him to phone through to double check. Aslong as its behind the front axle your safe also the usual not supposed to be excessively loud but thats at the tester disgretion(sp?) Yes i moved to the darkside |
3rd Dec, 2010 at 09:56:56am
Been ok'd by the person who will be doing my mot On 17th Feb, 2011 apbellamy said:
3rd Dec, 2010 at 10:19:58am
In that case go for it, will look and sound nice. good luck with it. |
3rd Dec, 2010 at 10:22:56am
If you've got the turbo like the one in Joe's car, how are you going to get the carb in?
3rd Dec, 2010 at 10:26:06am
I say go for it.
Edited by minimole23 on 3rd Dec, 2010. On 7th Oct, 2010 5haneJ said:
3rd Dec, 2010 at 01:26:14pm
Coupe had a turbo mounted like this with a 3" bore going to a bike can (think it was a bike can) and if i remember correctly it was quite loud it came out behind the front wheel on the bottom of the A panel. he will correct me if im wrong :)
3rd Dec, 2010 at 01:58:38pm
Also contemplating whether to add a screamer type wastegate but need to study this, what it's all about and wether it will really benefit me On 17th Feb, 2011 apbellamy said:
3rd Dec, 2010 at 02:00:51pm
someone was selling a homemade one that looks the dogs! have a quick search, i dont think it was sold it shouldnt be more than a month old the topic? its for a t3 though i think. |
3rd Dec, 2010 at 02:02:07pm
Mine will sit higher ie out of the bonnet and further forward so the carb will fit nicely behind and below it. If it ends up too loud I'll just route it another way but I won't find this out untill it's done.
If you've got the turbo like the one in Joe's car, how are you going to get the carb in? I think that exhaust would be fooking loud too. Like a chav's saxo! On 17th Feb, 2011 apbellamy said:
3rd Dec, 2010 at 04:55:20pm
joe C that engine give me the horn. I run a supercharger and I don't care the TB is on the wrong side.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
3rd Dec, 2010 at 05:18:04pm
On 3rd Dec, 2010 Rick.SPI said:
Mine will sit higher ie out of the bonnet and further forward so the carb will fit nicely behind and below it. If it ends up too loud I'll just route it another way but I won't find this out untill it's done. On 3rd Dec, 2010 apbellamy said: If you've got the turbo like the one in Joe's car, how are you going to get the carb in? I think that exhaust would be fooking loud too. Like a chav's saxo! i once (had to) run my car with no exhaust on my mirage manifolds, i only needed to go 3 miles,to collect the new exhaust but FK me its far too loud with out a scilencer, even with i doubt it'l be anygood, what are you plannig carb wise then?as above... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
3rd Dec, 2010 at 06:31:24pm
Hiff44 mate. Going to sit that behind either on the standard manifold or if needed on a swept down manifold. Will have to wait till I can mock up to see what needs what. On 17th Feb, 2011 apbellamy said:
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
3rd Dec, 2010 at 08:22:23pm
I assume you'll have a manifold made up to have the carb far away from the (really hot) turbo.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
4th Dec, 2010 at 01:06:08am
I was planning to have the turbo as far away as on a standard metro or more if possible. And heat rises. As said nothing is set in stone and needs to be mocked up to see what's possible. A remote turbo would require me to have a remote servo wouldn't it? Edited by Rick.SPI on 4th Dec, 2010. On 17th Feb, 2011 apbellamy said:
4th Dec, 2010 at 09:16:05am
If you're putting it in a genuine clubman, it won't have a servo. They came in in the mid 80's On 11th Feb, 2015 robert said:
4th Dec, 2010 at 11:51:12am
It not in a clubby at the moment I've got to save for that one. Itl be in my cooper for a year or so. On 17th Feb, 2011 apbellamy said:
4th Dec, 2010 at 06:37:02pm
GT clubbies had remote servo's from the factory I do believe. If something is worth doing, it's worth doing half of. |
4th Dec, 2010 at 10:37:54pm
did a lil drawing :)
