| Home > General Chat > WOW! im amazed by quick release engine mounts | |||||||
4th Mar, 2005 at 03:15:23am
These things are too good to be true! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
4th Mar, 2005 at 05:42:56am
ther good BUT on my daily driver the "pins" got gunged up pretty quick. so was a good idea to grease every time you used em. also removeing teh pin can be a royal pain until you master teh "technique" .. wel whatever technique works for you turbo 16v k-series 11.9@118.9 :)
4th Mar, 2005 at 08:21:57am
Ive got some ready to fit, about a tenner each. look to be good quality but as i said i havent tried them |
4th Mar, 2005 at 10:32:32am
I think they are crap - it was always really hard to drop the engine into them. One side would go in and then the other wouldnt, you have to lower the engine perfectly level and in just the right place to make um work. Removing the engine was very quick tho as the pins just pull out.
4th Mar, 2005 at 02:53:09pm
could anyone post some pics hear for all to see
![]() 1014 Posts Member #: 238 Post Whore essex |
4th Mar, 2005 at 05:00:53pm
i have a set of these fitted on my car, as sumpnut says the engine has to be perfectly dropped onto them and even then the pins are very fiddly to get through.
4th Mar, 2005 at 05:03:01pm
i dont like the idea behind these.
4th Mar, 2005 at 05:03:04pm
I have always got on well with the mounts that have their own captive nut on the inside of them? As they are not that difficult to line up, the fiddly part I find is getting your arm down the back of the clutch cover to get the nut started.......
![]() 127 Posts Member #: 439 Advanced Member derbyshire |
4th Mar, 2005 at 08:45:08pm
i agree with tom, ive seen these quick release ones fail, there only poly and it splits easy if not compressed, i personally just weld the nuts to new standard engine mounts, a lot easier than fiddling with nuts lol, and you get the same effect as standard.
31 Posts Member #: 478 Member Ooop Norf (Cumbria) |
26th Apr, 2006 at 09:24:37pm
Excellent stuff - glad I did that search now !
Clubbyestate : Brown and loud - fast soon ! |
26th Apr, 2006 at 09:27:17pm
this is a well old thread lol!!! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
26th Apr, 2006 at 09:32:40pm
On 04/03/2005 17:03:04 Tom Fenton said:
I have always got on well with the mounts that have their own captive nut on the inside of them? As they are not that difficult to line up, the fiddly part I find is getting your arm down the back of the clutch cover to get the nut started....... i dont get you, surely the bolts just thread in from the wheel side and the nut is welded on so you dont need to hold it, mine were anyway before i changed back to standard lol. |
1300 Posts Member #: 829 Post Whore essex |
26th Apr, 2006 at 10:39:21pm
1293 Turbo mini
