| Home > Help Needed / General Tech Chat > Ignition timeing, very low compression(8:1) engines... | |||||||
17th Nov, 2003 at 02:05:56am
Got the engine in and runningn before i went into work . took it for a wee spin round the block. turbo 16v k-series 11.9@118.9 :)
17th Nov, 2003 at 05:48:57am
Just looked at my ignition map for you
17th Nov, 2003 at 07:43:31am
Jimster,
17th Nov, 2003 at 07:48:53am
Cheers, What CR you running out of curiosity? and 56degrees turbo 16v k-series 11.9@118.9 :)
![]() 48 Posts Member #: 22 Member |
17th Nov, 2003 at 10:29:15am
good news mate!
17th Nov, 2003 at 06:35:55pm
I have reading of around 40 degrees on mine Jukka - I suspect that the software was not properly Zero'ed to TDC, and that Jims is the same!(yes Jim, i know i was there!)...
17th Nov, 2003 at 06:41:25pm
just thought about this more Jim...
Edited by turbodave16v on 18th Nov, 2003. On 17th Nov, 2014 Tom Fenton said:
18th Nov, 2003 at 09:00:56am
It is my understanding that if the volumetric efficiency of the engine is lowered(i.e. lower the CR) then more advance is needed as the fuel burns slower VE remains the same as it is a function of inlet, head and exhaust flow... by lowering the CR you have reduced the cylinder pressure that the burning of the mixture creates. This lower cylinder pressure will give your pistons less of a push down the bore and so you have less power. Timing wise, your mixture is less volitile so should stand more advance, but the engine is always going to feel flat. The only thing to think about is that there is now more charge in the head, and so too much advance will lead to det as there are plenty of cold surfaces and areas to get trapped end gasses. Basically, suck it and see. Alex AlexF |
18th Nov, 2003 at 05:04:48pm
U sure!? I was under the impression VE was a function of the amount of power obtained from a given volume of fuel/air.(now you can see why i failed thermodynamics and fluid mechanics....) turbo 16v k-series 11.9@118.9 :)
18th Nov, 2003 at 05:32:36pm
lol u keep posting new topics instead of repling too!!
AlexF |
18th Nov, 2003 at 06:08:03pm
the engiens getting turboed, just not yet.. cant afford the ??? for insurance+parts. should be ok ?-wise in a month though. just wana get the engine so its driveable off-boost. as this car is a daily driver too.
20th Nov, 2003 at 06:28:40am
Yeah,
20th Nov, 2003 at 08:39:52am
vacuum advance canisters are more used for light throttle opperation to improve economy and emissions... at idle their effect is much less.
AlexF |
17 Posts Member #: 63 Member |
20th Nov, 2003 at 09:19:39am
Evo, i was in the same boat as you, but i had 7.5:! !!
20th Nov, 2003 at 06:07:22pm
were you the guy i e-mailed a while back!?
20th Nov, 2003 at 10:08:55pm
sounds like you need a dizzy curved for your engnie!!
AlexF |
21st Nov, 2003 at 06:11:32am
The latest Metro turbo dizzy gives roughly 20 degrees advance at idle. Mate?s engine refused to pull past 4000 rpm (tuned by ear in winter conditions, slippery and no grip). The operator did not first understand that it was timing related issue but thought that it did not get enough fuel. Finally he checked the timing at it was about 50 deg at 1000 rpm. Without the vacuum it dropped to 30 degrees. The timing was retarded to 10 degrees @1000 rpm without vacuum, vacuum reconnected and we were rewarded with some 60 extra hp. Note that it did not even pink, it simply would not pull past 4000 rpm ! The turbo was an ancient Holset that hardly gave any boost below 3500 rpm...
21st Nov, 2003 at 05:23:19pm
running the electric dizzy of a last-of-the-line carbed minis. Iv got it running as best as i can, pulls consistantly and i guess kinda well. but im fed up with the low end power. Really fed up, actually makes me hate driving the car. So heads off to get 1mm taken off it Edited by evolotion on 21st Nov, 2003. turbo 16v k-series 11.9@118.9 :)
21st Nov, 2003 at 10:25:27pm
or get another head!!!
AlexF |
22nd Nov, 2003 at 06:01:05am
but then id need to get that skimmed.... Im actualy guna get a recent, std unleaded 12g940 skimmed as opposed to the MG head as it was giveing me al sorts of gasket grief, and on closer inspection it doesnt have unleaded insers. may use it as the basis for my next head, if i take this project that far. turbo 16v k-series 11.9@118.9 :)
beter start looking into mapable ignition myself then! as il no doubt have to run more.:(
