| Home > Help Needed / General Tech Chat > Shooting up revs while driving | |||||||
![]() 558 Posts Member #: 8143 Post Whore London |
4th Dec, 2010 at 06:30:59pm
4th Dec, 2010 at 06:34:33pm
Clutch is slipping by the sounds of it Rahul. If something is worth doing, it's worth doing half of. |
4th Dec, 2010 at 06:48:57pm
Ah bollocks! >_<
Edited by dischub on 4th Dec, 2010. |
4th Dec, 2010 at 06:54:40pm
Does it mean I need a heavier diaphragm? I changed it to an Orange from grey as the grey was a pain for everyday driving
4th Dec, 2010 at 07:01:56pm
have you had the lugs on the back plate machined down a bit to get a bit more clamping force? On 11th Feb, 2015 robert said:
4th Dec, 2010 at 07:04:00pm
May not be returning properly or lug heights not set properly. I doubt it would slip at "any speed" if the diapraghm was a bit light. An N/A 1380 isn't going to be pumping out turbo torque. If something is worth doing, it's worth doing half of. |
4th Dec, 2010 at 07:07:49pm
Also when you say checked it over did you measure the thickness or just checked for oil contamination? If something is worth doing, it's worth doing half of. |
4th Dec, 2010 at 07:22:29pm
I haven't checked if the lugs were machined properly, the engine was built before I bought the car, but its all MED stuff so I assume they have taken care of that?
4th Dec, 2010 at 10:08:30pm
On 4th Dec, 2010 apbellamy said:
have you had the lugs on the back plate machined down a bit to get a bit more clamping force? !!!! i was just about to post a topic on this. my grey diaphragm is slipping and i was wondering by how much i need to get it machined down? the clutch friction plate is slightly worn (6 paddle) and the backplate and flywheel are a bit scored too. it slips when i have it at 9psi but its fine at 5psi so its badly slipping, it should easily take a hell of a lot more torque than what its getting at 9psi? sorry for slight hijack :) |
4th Dec, 2010 at 11:34:45pm
There is lots of snow and ice....you sure it isnt spinning ? lol 9.85 @ 145mph
5th Dec, 2010 at 09:35:36am
Nope not much here in London, its all melted away! |
5th Dec, 2010 at 09:51:13am
have you had the lugs on the back plate machined down a bit to get a bit more clamping force? !!!! i was just about to post a topic on this. my grey diaphragm is slipping and i was wondering by how much i need to get it machined down? the clutch friction plate is slightly worn (6 paddle) and the backplate and flywheel are a bit scored too. it slips when i have it at 9psi but its fine at 5psi so its badly slipping, it should easily take a hell of a lot more torque than what its getting at 9psi? sorry for slight hijack :) Don't want to sound like a BAC, but have a search
From memory it's about 1.5mm to come of, but you really need to assemble the flywheel and measure your setup. The drive straps need to be as flat as possible. On 11th Feb, 2015 robert said:
5th Dec, 2010 at 10:07:34am
1.5mm is the generally accepted "safe" amount. But as Andy says get it assembled and when assembled you want the spring in the diapraghm to be near as damn flat for maximum clamping force. You may need to get the spacers for the drive straps slimmed down (or even get larger ones)to them to sit near as damn flat. If they go down "slightly" towards the flywheel this is fine too. If something is worth doing, it's worth doing half of. |
5th Dec, 2010 at 11:45:31am
Taken it out this morning and its stopped doing it?
5th Dec, 2010 at 11:50:53am
Sounds like a good way to f**k up your split rims using them when there is salt on the roads! I would recommend you clean them thoroughly as soon as possible.
5th Dec, 2010 at 02:07:34pm
cheers guys, i will have a search :) |
5th Dec, 2010 at 04:23:11pm
Tom,
Edited by dischub on 5th Dec, 2010. |
