Home > For Sale > 45 weber, alloy rocker cover, vp3c cam
philc
Member #: 1346
bromsgrove
45 weber with k&n filter, rams & linkage, all In working order £180
Choke is 36
Aux choke is 35
Trumpets are approx 65mm
Pump jet 40
Idle jet 50
Main Jet 145
Alloy rocker cover with breather outlets, £40
This is a kent version of a crane vp3c cam, used £25
blister
Member #: 2590
Croydon
would you take twenty for the recover coveR?
philc
Member #: 1346
bromsgrove
£30 +pp
I'll have the cam if it doesn't need a regrind.
Did this carb sit on the engine you're selling?
philc
Member #: 1346
bromsgrove
i could not say if the cam needed a regrind, i will get it checked
yes to your next question
How much power did it make? Was it this cam, and the Longman head?
