| Home > Wanted > Space Heater needed ASAP | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
6th Dec, 2010 at 06:40:22pm
as you all know its fcuking cold out and i cant do a lot up the garage without some heating
6th Dec, 2010 at 08:48:47pm
gold dust! |
6th Dec, 2010 at 09:14:44pm
machine mart look for the X55
6th Dec, 2010 at 09:45:02pm
Whilst you have to sort a flue etc...consider a wood burning stove, or better still, a waste oil burner
Edited by stevieturbo on 6th Dec, 2010. 9.85 @ 145mph
6th Dec, 2010 at 11:52:42pm
Thats interesting Steve - we've got one of these which we run on cherry without any great issue other that it is a bit small for our workshop.
On 6th Dec, 2010 BENROSS said:
machine mart look for the X55 but in this very cold weather you must use parafin kerosean ..red diesel will choke you below 0 deg when the fuel never gets warm at ground level even winding the pump pressure up is usless on diesel in thes ambient temps |
7th Dec, 2010 at 07:13:48am
Makes a lot of sense, mine which usually burns really clean was really smoky and horrible last night on diesel. I'll have to get some Kerosene.
7th Dec, 2010 at 08:15:37am
You could add a little petrol or meth spirit to the diesel. (dad used to do it in the trucks to stop diesel waxing) If something is worth doing, it's worth doing half of. |
7th Dec, 2010 at 09:17:42am
apparently that was a trick for getting through the taxi test years ago as well |
7th Dec, 2010 at 01:51:17pm
thanks for the link stevie, i spoke to a mate last night whos just made a second wood /oil burner for there unit, check out the area52 thread on RR, they used an old gas bottle for it so i may follow suit, im going to be making air receivers from two propane bottles so can make the 3rd into a burner/stove as i need to warm my pies and tea up too :)
Edited by pickmeup on 7th Dec, 2010. |
