Home > Help Needed / General Tech Chat > Dry decking (again..)
Amp
Member #: 7856
Morning all,
I'm planning on dry decking my turbo build, but have a question before I get too far!
I'm only doing it for the more consistent coolant temperatures etc, not for head gasket purposes, so how comes I have to still block up the waterways on the block/head? Could I not get away with leaving them, and putting the water port on the head still, or does that make the modification pointless as there won't be much flow?
Thats all, Cheers!
The point of dry decking (for cooling) is to get the water to flow down the block from the pump and then back accross the head. This promotes more even cooling on all 4 cylinders.
If you leave the head and block open, the water will still flow through the original waterways. Some water will flow through the dry deck ports, but you loose the even flow around the block/head. You would get away with just doing either the head or the block.
The other main point of dry decking is so that should the head gasket fail during a race you don't get oil flowing into the water or vice/versa and can still finish.
Amp
Member #: 7856
Thanks for the replies, I knew that from my searching John, but it's really just for cooling for me!
Thanks again Andy :) More work that has to be done I guess, just trying to get out of it!
Do it once and do it right!
Johnny
Member #: 6926
Accrington
why dont engine manufacturers do this? what are the conns to it?
Advantage
Member #: 1450
Near Paris - France
Alpa just blocked off the cylinder 1 & 2 front water holes and he seems happy with it.
There is a picture un his build thread
Rusty by nature
jamestar
Member #: 9159
Devon
anyone seen this from med?
http://www.med-engineering.co.uk/product_d...69&vlang_id=512
Kind of defeats the purpose in my opinion as you have oil and water touching the gasket still.
millermilla
Member #: 9126
Burgess Hill, West Sussex
Yeah but you still get more even cooling
www.shine-ebits.co.uk
Dry deck ports from Fast Carl/Turbo Phil, a hole in head and some plugs don't come to £150!
paneermeel
Member #: 1404
The Netherlands
[quote=Amp,10th Dec, 2010]Morning all,
quote]
Í also want to dry deck mine engine, but is it possible to do this with each cilinderhead.
The workshop who is doing some work for me is telling me that the head seems very thin where the adaptor should go. I don't want the head to be ruined because it is already got the ports flowed.
I was thinking that not every casting is the same so i just got a thiner one.
What are youre experiance with this?
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
Mine's not massivly thick. I can measure it if you like.
paneermeel
Member #: 1404
The Netherlands
Yes please,:)
But i'm talking about a cilinderhead , notting else*happy*
A question. What are you using to get a good seal?
At the left bottom you only have the pipe that goes into the head to get a seal.
www.turbomini.nl
The bottom left quarter is 5mm thick the other 3/4 is around 8mm thick.
It will be sealed with RTV. The pic is a little deceptive. With the port fitted, there is around 1mm gap at the bottom left with no screw fitted at that side. It should seal up fine.
I have no concerns other my girth *wink*
paneermeel
Member #: 1404
The Netherlands
RTV, what is that?
www.turbomini.nl
Room temperature V... (viscous springs to mind, but is wrong). Basically it's a sealant that sets at room temperature forming a water and oil tight seal. Used a lot in engine building, at least by me anyway.
Edited by apbellamy on 11th Dec, 2010.
fernox is good stuff for this sort of stuff,
er, stuff...
metroturbo
Member #: 989
North Yorkshire
Vulcanising
That's the one
On 18th Dec, 2010 metroturbo said:
Vulcanising
Live long and prosper!
geek
Cock lover!
love is a bit strong, I think like is more appropriate
I 'love' my cock. I'd be devastated if I lost it.
If I 'liked' my cock, I wouldn't be too bothered about loosing it.
