Home > For Sale > Lots of engine goodies, SC/CR Box, 1293 Engine etc..
racer_pete
Member #: 4826
Isleworth
Due to wanting a change of motor, its time to sell up my collection of engine parts, most of the parts have only been used for a couple weeks on the mini anyway here goes.... *frown*
'Stage 4 Spec' Leaded 12g940 head by Turbo-Phill, 36x31 valves 19cc in chambers, Brought brand new off Phil less than 2months ago! has only done 80miles since ive fitted it!!! heres the full spec - http://www.turbo-mini.com/66091/66153.html - £375
MED Fully Prepped 1293cc block ( 20) 21253 8.4cc dished Pistons, Decked Block, Arp rod bolts, tufrided/balanced crank 10/10, Held good oil pressure, tail has slight markings but nothing bad. only ran for 80miles £350
296 Billet Kent X-Drilled camshaft, done 80miles still has coating on, basically brand new! £120
Pre Verto Clutch Assembly, Comes with MiniSport 'Ultra light
flywheel' MED Race Backplate, Orange Diaphram, AP organic Plate (only done 80miles basicly new!) also balanced by classic and modern engine services £180,
Aldon Red 100ARP Dizzy, Brought couple months ago new, done 80miles, comes complete with rotor,cap and new luminition 8mm blue leads - £120
Luminition Mega Spark Coil with ballast resistor, used for 80miles again, £20
Hif44, comes complete, with a brand new alloy inlet from Moss, came off mini working perfectly, ready to be fitted, currently has BDR needle in + K&N filter - £80
New 1275 Engine Bracket £6
Plastics4Performance 2x Rear Quaters & Rear Screen 4mm Clear poly, both to be bolted/rivited in. brought these in the TM group buy a couple months ago, never got a change to put them in, havent even taken them out of packaging, only to take picture today.
(all items are excluding delivery)
Cheers, Pete 07985740698
edit- cant spell
Edited by racer_pete on 14th Dec, 2010.
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
is that the the alloy/alloy duplex
Interested in the rockers and the duplex. Will you do them for £180 posted?
racer_pete
Member #: 4826
Isleworth
Chris, Its not the 'full alloy' duplex, Will you have PM.
mini.cooper998
Member #: 3772
Wigan
what was the rad like for cooling the turbo motor
if it stayed in the middle first dibs.
also how much for the perspex
Andy
dischub
Member #: 8143
London
Would you sell the clutch plate and orange cover separate?
Turbo_Jonesy
Member #: 9041
PM on coil and rad
racer_pete
Member #: 4826
Isleworth
mini.cooper998 - I wasent running a turbo, was just a n/a 1293, but kept it cool for me, i paid £120 for the perspex in the group buy so say £110?
rahul - would rather sell as a package really
turbo_jonesy - havent got any pm's buddy, dont know if its working or not? *Idea*
dischub
Member #: 8143
London
No problem mate, sorry for going off topic here but how come your splitting the engine? Selling the car?! *frown*
Midas
Member #: 7555
I've just seen this after posting on your other thread, are these rockers that same as the ones offered in your other thread?
http://www.turbominis.co.uk/forums//index....p=vt&tid=396453
racer_pete
Member #: 4826
Isleworth
I know :(, Ill probably regret it sooner or later, but i want a change, thinking along the lines of mk2 escort.
racer_pete
Member #: 4826
Isleworth
- yes they are Midas
Midas
Member #: 7555
I've offered to buy the rockers on the other thread, looking at the times I'm behind Will in the queue who as offered on here.
just_jack
Member #: 2928
peterborough
pm for gbox
Jack Jones
alaskanow0
Member #: 8466
Mansfield
Hi, I will take the med backplate, alloy duplex please.
racer_pete
Member #: 4826
Isleworth
duplex, rockers, and med front plate now sold
james962
Member #: 3663
Banbury
Does the rad have a drain plug/ sensor tap on the bottom at all?
racer_pete
Member #: 4826
Isleworth
yes has a drain plug,
how much for the Rad posted?
racer_pete
Member #: 4826
Isleworth
£45 posted?
racer_pete
Member #: 4826
Isleworth
rad & s/c box sold pending collection
Ozyris
Member #: 9054
Disneyland Near Paris
Hi hif 44 always on sale? =) i'm interested =)
pm'd =)
Cables
Member #: 9270
has the box gone?
Anyone got any bits from this guy yet?
It's all gone a bit quiet.
dimphy+maikel
Member #: 7711
Beek, The netherlands
How much would cost shipment to holland for the 1293 block?
Regards maikel
