Home > Show Us Yours! > mini cemt mixer
16kw
Member #: 9222
i dont seem to get them big, two pictures taken at a mini show are on flicker austin mini cement mixer
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
put them on photo bucket and the pic will be bigger
boostjunkie
Member #: 9117
Northampton
wow thats a new one!
16kw
Member #: 9222
put pics onphoto bucket, what do ido next
In your photobucket album, if you hold the mouse over any picture, a list of options will appear below it.
Go to the one that says IMG code and click on the code and with most browsers it will be automatically copied (the code window will briefly say "copied"). On older browsers you have to copy it using the edit/copy commands but, either way, just go back to the TM forum and paste in the box where you are typing.
A long string will appear with IMG in square brackets at the front and /IMG in square brackets at the end. Do this for as many pictures as you like.
Once you have posted your text (or if you do preview post) the TM forum software reads the IMG code(s) and goes and fetches the picture(s).
oh dear go,
good gimmic......
i had a real working one in the back of my truck, that i dropped off.......
doubt it'l fit now with the engine in its place....
16kw
Member #: 9222
16kw
Member #: 9222
16kw
Member #: 9222
16kw
Member #: 9222
boostjunkie
Member #: 9117
Northampton
does it work? bet it weighs some!
boostjunkie
Member #: 9117
Northampton
turbomininick
Member #: 9265
think its just too plastic plant pots joined together *happy* so dout it works
