| Home > Wanted > Central Heating Pump wanted | |||||||
12th Dec, 2010 at 04:32:50pm
As title has anyone got an old but working c/heating pump kicking about their garage?
12th Dec, 2010 at 04:33:25pm
I ask my plumber mate see if he has one. If something is worth doing, it's worth doing half of. |
12th Dec, 2010 at 04:36:36pm
Bugger, I threw one out a month ago I seriously doubt it! |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
12th Dec, 2010 at 10:16:35pm
If you can find or have a bilge pump from a boat, that will work fine as well tom. We have a big lathe a work that we fitted a bilge pump to, just take the two wires straight to a (usually dead) battery and connect a charger up. Its not as good as a propper set up, but for the use it gets, it works perfect!! And on the 7th day........... God created turbochargers! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Dec, 2010 at 10:09:37am
what would you use for coolant?
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
15th Dec, 2010 at 11:25:25am
I've asked my plumber mate but he's about as reliable as a plumber. Quick search on the old ebay revealed this.
15th Dec, 2010 at 11:33:19am
Or
15th Dec, 2010 at 12:33:37pm
On 13th Dec, 2010 rubicon said:
what would you use for coolant? obviously not water? or...... I thought coolant was a 50/50 mix of mineral oil & water but I may have got that wrong. Isambard Kingdom Brunel said:
15th Dec, 2010 at 02:34:41pm
Soluble oil (whatever that is?) and water mix. I reckon a c/h pump should probably cope with it OK.
