| Home > General Chat > accralite forged pistons | |||||||
1083 Posts Member #: 8932 Post Whore |
21st Dec, 2010 at 10:27:35pm
So i'm now in the market for pistons, and i thought i saw the accralites on the avonbar site for £300 not so long ago. I've just been on avonbars site and they weren't there, then i found them on avrs site for £450. Am i going mad or has the price gone up?
Edited by george91 on 21st Dec, 2010. |
21st Dec, 2010 at 10:28:46pm
Yep. Omega now own Accralite and have jacked up the price. If something is worth doing, it's worth doing half of. |
21st Dec, 2010 at 10:30:36pm
Bastards! On 28th Aug, 2011 Kean said:
21st Dec, 2010 at 10:34:29pm
Correct! If something is worth doing, it's worth doing half of. |
21st Dec, 2010 at 10:35:40pm
Shite guess i'll be getting omegas then, forged or cast? Edited by george91 on 21st Dec, 2010. |
21st Dec, 2010 at 10:39:26pm
I think the forged omega's are even more than the accralites!!
22nd Dec, 2010 at 12:01:09am
I'll go for cast omegas then, cheers Joe. |
22nd Dec, 2010 at 12:16:33am
That's more than I paid from Avonbar before the price went down!
In the 13's at last!.. Just |
22nd Dec, 2010 at 08:03:21am
I'd say the cast Omegas are more than up to the job for most folks. Since fitting mine over 2 years ago I've run a minimum of 15psi on the road and up to about 20psi on the rollers. |
22nd Dec, 2010 at 09:19:24am
you could use forged omegas but their price over 400 sheckels,
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
22nd Dec, 2010 at 11:14:33am
Set up well cast would be more than fine. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
400 Posts Member #: 2563 Senior Member Tamworth |
22nd Dec, 2010 at 12:08:57pm
So do we rekon the cast omega's are ok for a short stroke 970 turbo? Bout 18psi, 10,000rpm?
22nd Dec, 2010 at 01:11:39pm
i brought the last set of +20 accralites for 300 from avonbar 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
22nd Dec, 2010 at 01:24:06pm
Pfft your off my xmas card list then! If something is worth doing, it's worth doing half of. |
22nd Dec, 2010 at 01:53:56pm
Yes shop around maybe you can get then a better price then av? Best 1/4 mile 13.2 seconds @116 mph
22nd Dec, 2010 at 04:17:52pm
On 22nd Dec, 2010 01smartc said:
So do we rekon the cast omega's are ok for a short stroke 970 turbo? Bout 18psi, 10,000rpm? I wouldn't. On 13th Jul, 2012 Ben H said:
22nd Dec, 2010 at 04:20:49pm
10. 000 rpm is a little optomistic
22nd Dec, 2010 at 04:29:11pm
From my limited knowledge, I'd say something like the ultra lightweight forged omega's would be better suited. If something is worth doing, it's worth doing half of. |
22nd Dec, 2010 at 09:18:05pm
On 22nd Dec, 2010 BENROSS said:
10. 000 rpm is a little optomistic Guess we will see :)
22nd Dec, 2010 at 11:44:27pm
No one will be able to tell you for sure if A piston will take the rpm AND the 18psi boost you intend. I doubt there has been anyone who has run such a combination knowing it. Fast Carl has run 9k plus with Minispares Mega pistons and I believe they may have touched 10k, but i would be sure that it was not under power.
Edited by Sprocket on 22nd Dec, 2010. On 26th Oct, 2004 TurboDave16v said:
23rd Dec, 2010 at 12:30:09am
Thanks for the help all, i'll have a shop around but avonbar at £411 are the best so far. If anyone has seen a better price let me know. Cheers |
23rd Dec, 2010 at 01:08:09pm
On 22nd Dec, 2010 Sprocket said:
No one will be able to tell you for sure if A piston will take the rpm AND the 18psi boost you intend. I doubt there has been anyone who has run such a combination knowing it. Fast Carl has run 9k plus with Minispares Mega pistons and I believe they may have touched 10k, but i would be sure that it was not under power. You are pioneering what you are intending to build, and I would have thought that an engine builder should know what is required of a piston rather than asking on a public forum, but then that is just my opinion. If you are building a motor as you intend, to do what you ask of it, I would have expected to use parts designed for the intended RPM rather than something off the shelf intended for more often than not 7k. Longer Saenz rods on 'S' big ends, custom pistons with 18mm pins from Wiseco and an aluminium or Titanium flywheel from Force Racing or a one peice swiftune steel flywheel as a last resort. 10k would then likely be a breeze in the park. It was more to explore public opinion of the cast pistons and to invite some interesting conversation rather than to actually advise me on my engine build. I am using Cosworth Pistons :) Chris
