| Home > General Chat > garage lighting | |||||||
29th Dec, 2010 at 10:50:13pm
Currently my garage doesn't have any kind of lighting what so ever and im looking to sort this asap!
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
29th Dec, 2010 at 11:20:14pm
I used to light my (small) garage with four Halogen lamps, one in each corner.
29th Dec, 2010 at 11:32:25pm
They aren't a very nice light to paint with Matt, the florrys will be better if a little more costly. |
603 Posts Member #: 1938 Post Whore near Dundee |
29th Dec, 2010 at 11:35:41pm
florescent lighting dosent have to be costly matty.
29th Dec, 2010 at 11:41:24pm
if you paint the inside of your garage white it will help alot with the lighting! My build thread..
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
30th Dec, 2010 at 12:02:05am
i was looking at getting some strip lights and was rather supprised when i saw the cost so im not supprised your trying to find something a touch cheaper David. |
347 Posts Member #: 9075 Senior Member Peterborough |
30th Dec, 2010 at 07:25:30am
My dad has one of those lights you linked to Matty and while they're good to provide extra lighting when working in an attic or when you've got the power off to wire in new lights etc. I wouldn't want to use them as the main power source.
![]() 552 Posts Member #: 300 Post Whore Cumbria |
30th Dec, 2010 at 10:05:20am
just get some big striplights and as has been said paint the walls white if you've not already done so, it makes a big difference. Here for the craic..
30th Dec, 2010 at 10:09:07am
Ive heard of those lights igniting paint fumes. I seriously doubt it! |
30th Dec, 2010 at 10:41:11am
They do indeed get very very hot, halogen lamps don't last all that long and consume a lot of electricity too. 4 x 400w lights will need a fairly decent supply - 5amps plus your air compressor - youll be close to the extension leads limit. How far is the garage from your house? On 7th Nov, 2011 apbellamy said:
30th Dec, 2010 at 10:44:37am
Do it right and do it once. Go and get some fluorescents.
30th Dec, 2010 at 10:46:13am
the halogen lights will ignite fumes - been on the receiving end of it that resulted in a car getting scorched! they will also cost a fortune to run and seem to go through bulbs at an alarming rate.
30th Dec, 2010 at 01:20:33pm
use the daylight tubes ....a must!
30th Dec, 2010 at 02:06:09pm
The first tubes I got were liberated from a building site (with permission) from a building that was being levelled so you don't have to buy new! On 5th Sep, 2011 Vegard said:
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
30th Dec, 2010 at 02:14:24pm
Flourescent light assembly from Wickes, about £8 each. |
30th Dec, 2010 at 03:01:14pm
Yep, florescent fittings are cheap enough. I have 4 twin 5ft one in my garage, plus a single 6ft one over the work bench. Work a treat. Oh and they cam fromWickes as that was the cheapest I could find. http://www.twin-turbo.co.uk
30th Dec, 2010 at 04:06:17pm
i have 2 four foot lights in our garage and its plenty of light
30th Dec, 2010 at 06:58:27pm
I equipped my workshop from light fittings and tubes that were being chucked out at work - I have 6 x 6ft doubles and 2 x 6ft singles and its like daylight in there. - you have seen it Matt.. |
30th Dec, 2010 at 08:07:03pm
Thanks for the replies lads, I won't be using halogen if there is chance of ignition then!
30th Dec, 2010 at 08:18:25pm
Don't forget that strip lights have a warm up period, like energy efficient lights. So don't be disappointed if they seem dull when you first turn them on. I know I was...... http://www.twin-turbo.co.uk
30th Dec, 2010 at 09:48:55pm
Lots of flourescent tubes, job done.
30th Dec, 2010 at 10:39:33pm
or blowing out given the slightest knock when hot... "Turbo's make torque, and torque makes fun"
