| Home > Help Needed / General Tech Chat > power expectancy? | |||||||
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
4th Jan, 2011 at 07:39:53pm
guys and gals
On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
4th Jan, 2011 at 07:43:34pm
boost? |
4th Jan, 2011 at 07:51:14pm
i dunno?????? not sure what the t2 boosts at or to? On 5th Jan, 2011 wolfie said:
4th Jan, 2011 at 07:51:21pm
4th Jan, 2011 at 08:02:04pm
A turbo will boost to whatever you set the actuator to. Within reason of course.
4th Jan, 2011 at 08:08:08pm
i'll prob run low boost then, say 10psi? Edited by kenny2 on 4th Jan, 2011. On 5th Jan, 2011 wolfie said:
4th Jan, 2011 at 09:26:21pm
120 - 130, maybe 140 at a push imo Yes i moved to the darkside |
4th Jan, 2011 at 09:43:14pm
116 Posts Member #: 8367 Advanced Member bucks |
4th Jan, 2011 at 09:48:17pm
are you using the standard box and drops?
4th Jan, 2011 at 09:52:26pm
as per the mj only till i can afford the sc's. On 5th Jan, 2011 wolfie said:
4th Jan, 2011 at 10:21:26pm
i would only run about 8psi then imo without destroying the box or the drop gears! but that is just my opinion, i dont know what everyone else thinks?
4th Jan, 2011 at 10:31:25pm
standard mini gearbox's are safe up to about 130bhp, obviously t your own risk, i am at this sort of power atm, and im saving up for a sc box. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
4th Jan, 2011 at 10:44:21pm
thats grand i have a few spare box's and drops.... i have a jkd/sc final drive on a salsbury diff. might run that. On 5th Jan, 2011 wolfie said:
4th Jan, 2011 at 11:35:21pm
you will find if power levels approach above what has been mentioned, with your standard box third gear and the head set will shat its selfe, followed by the diff and the drop gears,
Edited by BENROSS on 4th Jan, 2011.
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
4th Jan, 2011 at 11:57:34pm
I think 130 is abit optimistic tbh. I'd say around the 100bhp mark give or take. On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
5th Jan, 2011 at 07:42:53am
100bhp seems low as a gearbox destroyer. The Metro turbo had 94bhp and ran for may thousands of miles with no problem.
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
5th Jan, 2011 at 08:42:01am
wil_h i dont think he ment 100 as the gearbox threshold i think he ment 100 as expected power output.
"Tuning should be a compromise between what is possible and what is necessary"
5th Jan, 2011 at 09:34:56am
alot of it depends on driving style treat it carefull from standstill and should be fine aslong as the bearings and layshaft are ok and drop endfloat is spot on, any of the above aint then bang always looking for them bigger bunches of bannanas |
5th Jan, 2011 at 09:44:44am
The standard used helical box in in our van is surviving with about 150 angry bananas and 170 curly wurlys being abused through it. It has s/c drops and a 4 pin diff though.
5th Jan, 2011 at 09:53:30am
^ Surviving so far. If something is worth doing, it's worth doing half of. |
5th Jan, 2011 at 10:02:19am
the worst it will have to do now is shunt the van in and out of the garage.... On 11th Feb, 2015 robert said:
5th Jan, 2011 at 01:34:29pm
have a x-pin in my n/a can throw it in or have a salsbury lsd..
6th Jan, 2011 at 05:12:42am
At the build time I would not use std cam, it's just been made to moove a low mower,
