| Home > Help Needed / General Tech Chat > Mpi Starting problems | |||||||
5th Jan, 2011 at 04:33:59pm
Hi all and happy new year.
6th Jan, 2011 at 05:07:19am
Try to strap a good earth point from alternator bolt to chassis just in front, it should cure your troubles.lmk |
2nd Feb, 2011 at 11:51:58pm
ok. just before you posted i cleaned, regapped the plugs and it went fine for a few more weeks. it then woudnt start again so added the extra engine earth. it wouldnt start again today.
Edited by welshdan on 2nd Feb, 2011. |
3rd Feb, 2011 at 05:50:36am
Have you got an acr4 or a mate with one around your area?
5th Feb, 2011 at 08:16:02am
Dan,
5th Feb, 2011 at 08:38:52am
5th Feb, 2011 at 10:59:32am
That is a common problem on all the injection minis.
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
5th Feb, 2011 at 01:58:44pm
On 2nd Feb, 2011 welshdan said:
when i built the engine the only mpi flywheel hosing available at the time was one from an accident damaged car. this has a hole in it about 1 inch square, not far from the flywheel/crank sensor. I've got a spare one somewhere in the garage. It's yours for postage only - if you want it. Drop me a PM. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
5th Feb, 2011 at 10:13:17pm
i got around to looking at the car today due to work comitments.. i removed the crank sensor and there was a load of oil/dirt on it from the hole in the casing. i cleaned it off. the car seems more responsive now, so i hope this was the problem. only time will tell due to the intermittent nature of the problem. next time i pull the engine i will change this casing. but i will keep this thread updated. i will also check the relay box tomorrow. thanks for the input |
18th Feb, 2011 at 01:55:19pm
ok, so i have been driving this for 3 weeks now with no problems. i dont want to tempt fate, but it seems to be the crank/flywheel sensor that was causing the problems. i hope i havent spoken too soon! cheers |
