| Home > Help Needed / General Tech Chat > Messed up - What bits do I need now? | |||||||
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
8th Jan, 2011 at 11:10:32pm
I tried to dill out the broken stud from the exhaust housing on my turbo below and made things worse.
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
9th Jan, 2011 at 12:05:54am
Well, Fair do's for trying to get it out,
9th Jan, 2011 at 12:22:57am
Its a tricky thing to do if you haven't done it before...It should drill out but you may have to keep re sharpening the drill bit.
Edited by matty on 9th Jan, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jan, 2011 at 12:31:46am
what matty says below!
On 9th Jan, 2011 matty said:
Its difficult to explain but the centre of the stud will not be exactly in the centre when you look at it as you have to take into consideration the thread that you can see. (eg one side of the stud you will see the trhead the other side you will see the thread of the housing). You need to drill it half the thread depth (0.6mm) bias the side part of the stud that you can see the thread on the housing. (looking at the pic its about at 7 O clock) if that makes any sense? On 28th Aug, 2011 Kean said:
9th Jan, 2011 at 12:44:19am
Oh yeah if you can get hold of a centre drill, that will make it easier to get it in the right place, if the part you are drilling isn't flat. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jan, 2011 at 10:01:13am
If, as he says, the stud has work hardened with the original drilling, maybe try a masonry drill - but will need a "green" wheel to keep it sharp |
9th Jan, 2011 at 11:47:37am
TBH, by far the easiest thing to do is take it to a professional who can repair it.
9th Jan, 2011 at 03:07:00pm
If it's a T3, just get a new turbo. I think Brett has one for sale at about £20 needing rebuild. Just use the two to make one good one. On 11th Feb, 2015 robert said:
9th Jan, 2011 at 05:33:05pm
Cheers all, tried to give it another go this afternoon and not much luck.
9th Jan, 2011 at 05:35:38pm
give the thermostat housing some persuasion with a soft hammer, then you shut be able to use stud extractors on the snapped bolts. On 11th Feb, 2015 robert said:
9th Jan, 2011 at 05:40:39pm
Fire may loosen the thermostat housing If something is worth doing, it's worth doing half of. |
9th Jan, 2011 at 05:41:20pm
Heating a seized bolt is the absolute last resort. Reason being as you have found once it has been hot it draws the carbon to the surface making it very hard, then difficult to drill.
9th Jan, 2011 at 05:43:26pm
destroy the top housing with a chizle leaving the studs exposed with some heat and alot ......... you should get some stiltsons on there and be able to remove the studs...
