| Home > Help Needed / General Tech Chat > 1098 options | |||||||
6 Posts Member #: 9291 Junior Member |
10th Jan, 2011 at 02:47:21am
Hi all, I'm new to the list and building up an A series 1098 Minor for my girls who are now driving age. All my recent previous experience has been on small and big block turbo/injected chevs, so this is a real change of pace for me. I do however know enough to be dangerous about the A-series from when I was a kid, and have studied Vizard's bible extensively. I also have experience in modifying carbs for blow-thru, and can fabricate. I want to create something reliable, tractible, that can climb hills and keep up with modern traffic, and be a bit of fun. We have access to premium unleaded fuel 98 RON octane.
10th Jan, 2011 at 08:20:22am
I'd say you pretty much have it about right turbo wise.
10th Jan, 2011 at 08:30:57am
The Metro turbo cam is a standard 1275 cam. A n/a MG metro or a 266 should work well in your application.
10th Jan, 2011 at 09:00:25am
I hesitate to offer advice to someone so obviously well informed, but do you think the 1098 crank will last very long ?
10th Jan, 2011 at 09:15:42am
It's revs that kill 1100 cranks, keep rpm to 6k and it's happy days.
10th Jan, 2011 at 10:03:35am
I'd agree with Wil, keep the revs down and they are OK.
10th Jan, 2011 at 10:48:53am
On 10th Jan, 2011 Tom Fenton said:
... I would guesstimate that the standard MG Metro (not turbo) cam will be good in your application. Thanks a lot for the advice chaps - excellent - I think I'll go the boost route, and have a couple of follow-up questions. In creating a decent integration of 12G940 on small bore unit, do I take the chamber walls out to the big bore gasket line around the valve areas, then put matching chamfered reliefs in the deck, and can I then turn the round dish in the hypatechs into more of a side to side trough that matches the valve reliefs in the deck, all as a means of getting the c.r. down? I think I need pushrods from the 1300 - is that right? Whats the practical upper limit for overbore - if I can track down +080 slugs is that safe What would be a ball-park needle/spring as a starting point in a blow-thru HS4 in an application like this? Thanks again. Andrew |
10th Jan, 2011 at 10:53:49am
A couple of additional thoughts- rather than having to modify the block you could get hold of a 12G295 head- with spacings to suit direct bolt on to a small bore block. If you get hold of an un-skimmed one they have a large chamber as they were originally used with a raised-dome piston.
10th Jan, 2011 at 11:34:30am
... I would guesstimate that the standard MG Metro (not turbo) cam will be good in your application. Thanks a lot for the advice chaps - excellent - I think I'll go the boost route, and have a couple of follow-up questions. In creating a decent integration of 12G940 on small bore unit, do I take the chamber walls out to the big bore gasket line around the valve areas, then put matching chamfered reliefs in the deck, and can I then turn the round dish in the hypatechs into more of a side to side trough that matches the valve reliefs in the deck, all as a means of getting the c.r. down? I think I need pushrods from the 1300 - is that right? Whats the practical upper limit for overbore - if I can track down +080 slugs is that safe What would be a ball-park needle/spring as a starting point in a blow-thru HS4 in an application like this? Thanks again. Andrew On 7th Nov, 2011 apbellamy said:
10th Jan, 2011 at 11:40:12am
Take look here, it's a good guide to fitting 12g940 to small bore blocks
10th Jan, 2011 at 07:32:57pm
On 10th Jan, 2011 almichie said:
Take look here, it's a good guide to fitting 12g940 to small bore blocks http://www.minimania.com/web/SCatagory/ENG...12/ArticleV.cfm that link was dead? Cheers |
10th Jan, 2011 at 08:30:50pm
Hmmm I checked the page and that's it, but your right the link doesn't work.
12th Jan, 2011 at 01:43:41am
Thanks, good info.
12th Jan, 2011 at 09:06:42am
The Spridget diaphragm spring clutch should cope, otherwise the Cortina/Capri pressure plate will fit, with re-drilling and facing off the flywheel. I use this just because I have a Ford centre plate to suit the Sierra gearbox I have fitted.
