| Home > Help Needed / General Tech Chat > 1.5 roller tip rockers | |||||||
![]() 78 Posts Member #: 8913 Advanced Member seaford, east sussex |
11th Jan, 2011 at 09:18:46pm
hi all. iv got a set of mini spares hi lift roller tip rockers with a solid spacer kit. the problem is at hi rpm in 4th some times 3rd gear my valves are sticking (not consistently) the head is new but not sure if its the head at fault or the rockers the guy who built the head said it could be the valves sticking when heat has built up. he will take the head back and fix it however i want to eliminate my workmanship first before i remove and send it back.
11th Jan, 2011 at 09:32:13pm
Rockers won't affect sticking valves. Are the roller tips properly aligned? On 13th Jul, 2012 Ben H said:
11th Jan, 2011 at 10:17:18pm
Are you sure that it's not the valve springs binding as a result of the extra lift?
In the 13's at last!.. Just |
11th Jan, 2011 at 10:51:29pm
if the head has manganise guides the gold ones fitted, and these have not been reamed when pressed in, theres you problem when the head warms up.
11th Jan, 2011 at 11:22:51pm
roller tips are properly aligned, springs dont appear to look as if they would bind, what happens if im to give it a skin fall at fall throttle mainly in 4th gear at 4000-4500 it will be pulling like a train and then run on 3 cylinders guessing its an exhaust valve sticking open cos my mate was behind me when it happened and he said he saw lots of flame shoot out the exhaust. once this has happend i stick in in neutral let it coast for 30 sec or so and i get 4 cylinders back again lol so im thinking its what benross has suggested . looks like im going to have to send the head back |
11th Jan, 2011 at 11:33:47pm
Sounds like the exhaust valves to me....
12th Jan, 2011 at 05:54:34pm
guide binding as above
