| Home > Help Needed / General Tech Chat > Fhooom..... | |||||||
84 Posts Member #: 255 Advanced Member |
9th Mar, 2005 at 10:29:33pm
Cylinder Head Gasket let go at the weekend on the M62 back from York.... Edited by NeXTGen on 9th Mar, 2005. |
10th Mar, 2005 at 12:04:28am
Most people use the Payen BK 450 head gasket which is the proper Turbo item. You should have no trouble with this, especially running 10psi, they're an excellent gasket, as many have proved.
Edited by Turbo Phil on 10th Mar, 2005. |
10th Mar, 2005 at 10:05:36am
would also like to add phil
Edited by BENROSS on 10th Mar, 2005.
10th Mar, 2005 at 07:43:41pm
unsercrown cooling jet pics info on www.miniwilliams.co.uk
10th Mar, 2005 at 08:28:11pm
heh- good point benross, but heres the wrap:
10th Mar, 2005 at 08:31:29pm
TRUE
10th Mar, 2005 at 10:09:08pm
Let you know when I've had the lump out of the mini - I've got to get the V12 out of the jag (bodywork scrap) before end of month so its going to be on hold a bit...
10th Mar, 2005 at 10:25:00pm
if i remember right
13th Mar, 2005 at 06:09:31pm
What headgasket have i got? I used the one avonbar sent me, its like a black rubbery silicone thing!!! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
13th Mar, 2005 at 10:12:18pm
silicone head gasket..... |
13th Mar, 2005 at 11:28:04pm
Sounds like the BK 450 to me.
14th Mar, 2005 at 12:01:06am
last time the gasket was blown!
15th Mar, 2005 at 07:51:34pm
Got it, had the head off, and its DEFINATELY the gasket. Head and block are pristine in EVERY way
244 Posts Member #: 34 Senior Member |
15th Mar, 2005 at 09:48:11pm
If your sure both the head and block surface are true, the clean up the head and inspect for any cracks. I use a 500W lamp over head, and carefully examine the head.
16th Mar, 2005 at 07:38:49am
Had it on an engineering bench and went over it with a dial gauge on an overhead mount.... Also straightedge and feelers. Flat as a pancake. same with the block!
17th Mar, 2005 at 11:07:53pm
Well my "bk 450" has taken 9 psi for a long time now and its happy :) definately using them in future Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
18th Mar, 2005 at 07:32:29am
Got it all back together, with the proper turbo part, running 10 psi, lets see...!
18th Mar, 2005 at 09:46:17am
NEXTGEN:
![]() 281 Posts Member #: 441 Senior Member |
18th Mar, 2005 at 10:17:51am
ben, have i gotta re torque my head up then? i thought i did but couldnt find anything in the haynes, its 50ftlbs on turbo's yeah?? thats what i did mine to,and 24 on the rockers |
18th Mar, 2005 at 10:44:07am
I heard this wasnt the case Ben....
18th Mar, 2005 at 10:56:03am
iain, dan
18th Mar, 2005 at 10:57:47am
OH! in the right sequence............. of course Edited by BENROSS on 18th Mar, 2005.
18th Mar, 2005 at 11:35:43am
cheers buddy |
18th Mar, 2005 at 11:40:32am
i do this anyway ben as its what ive been taught. saying that ive done some without re-torquing and they've been fine.
18th Mar, 2005 at 01:18:39pm
I've always retorqued the head after heating up and cooling it off a couple of times. It's always worked for me.
