| Home > Help Needed / General Tech Chat > Clutch won\'t come off a Metro Turbo motor... | |||||||
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
15th Jan, 2011 at 04:28:01pm
I have the engine out and stripping it down to rebuild so now at a point where the flywheel cover is off and I can clearly see the clutch etc.
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
15th Jan, 2011 at 04:35:31pm
you need a flywheel puller, the flywheels are quite stubborn
15th Jan, 2011 at 04:38:04pm
I have searched and that's what people say but isn't the metro a pre vento? It has 6 bolts holidng the clutch on.
15th Jan, 2011 at 04:44:37pm
Sounds like a vertoclutch to me,
15th Jan, 2011 at 05:01:02pm
Here is a photo of it. I think that I do need that puller as I can see three threadded holes for it to fit into.
15th Jan, 2011 at 05:07:21pm
that's verto.
15th Jan, 2011 at 05:19:05pm
Cool, wasn't too sure.
15th Jan, 2011 at 05:30:17pm
best to have the 6 bolts in when you pull it, as with the bolts out when the front bit comes off the rear bit can fall down and twat the crank.
![]() 174 Posts Member #: 9041 Advanced Member Essex |
15th Jan, 2011 at 06:04:13pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...IT#ht_500wt_949
15th Jan, 2011 at 06:19:00pm
Halfrauds sell the puller if you're in a hurry On 11th Feb, 2015 robert said:
478 Posts Member #: 1962 Senior Member Lancaster |
15th Jan, 2011 at 06:22:51pm
Look back at one of my posts, I had serious issues getting my verto off, ended up using an air chisel on the clutch to get it off |
15th Jan, 2011 at 08:21:46pm
On 15th Jan, 2011 Joe C said:
the flywheel can be pulled in any position, and yes you need to lock the flywheel, somthing wedged in the ring gear usually. Why do you need to lock the flywheel? Is it to help remove the bolt in the middle or does it need to be locked when pulling it off? Thanks everyone. Unfortunatley we don't have a Halfrauds in Jersey so will probably buy that one off eBay as is dirt cheap. Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
15th Jan, 2011 at 08:26:12pm
you have to lock it to do the puller up, you have to do the puller tight.
15th Jan, 2011 at 08:28:23pm
If you have a old shell casing put in in the flywheel where the starter motor sits that should lock it up good. You need to lock it up otherwise as you tighten the puller the engine will just turn over...!!
15th Jan, 2011 at 08:32:53pm
http://farm4.static.flickr.com/3476/338319..._33db6bb544.jpg |
16th Jan, 2011 at 10:53:59am
Looks OK apart from fitting the puller "plate" the wrong way around. Should work anyway though. On 13th Jul, 2012 Ben H said:
