Home > For Sale > 1 Ton Chain Block *Pics added*
Industrial 1Ton chain block. Used condition. I salvaged this from our work shop when they decided that it was costing too much to have the lifting gear tested every year in the thought it was easier to hire the gear instead. They were basically considered a liability. This block works perfectly well, it was in service untill its test was due, and is not your cheap nasty suspects. I have not used it since I brought it home. Just need to move it on. easily worth £15
Collection only, or delivered to Bingley
NOTE: I take no responsability for any damage to property or injury to any person or persons while using this equipment.
Edited by Sprocket on 20th Jan, 2011.
Any photos Colin? Interested.
im interested if will pulls out
Pic coming in the next ten minutes
The chains might (read that as will) need shortening for the average home user.
Yep, I'll have that.
Might be able to pop round next Thursday evening. Not sure about Bingley yet.
No problem, but I will have to let you know nearer the time if thursday is OK. I was suposed to be in scotland for a day on Monday. This might be wednesday or thursday now. I'll keep you posted
The other option is to maybe give it to Carl at Bingly and I'll sort him with money. I;ll have to ask Carl firt mind!
I can get it up to Leeds for you Wil
No Rush Wil. If there is an easy way to work it out, by taking advantage of others good will, I'm good with that too :) I'm over at Carl's often these days anyways.
I'll speak to Carl. But if you can get it there however, then that would be proably easiest. I can send a cheque, paypal a gift or something else
