Home > Help Needed / General Tech Chat > Lowering - shortening Hilos
Tareq
Member #: 970
Bahrain
Hi, I plan on setting my car up at Miglia ride height. Running on the competition cones and Hilos from Minispares.
I am about to shorten the Hilo bolts and was wondering if anybody knows if the aluminium part of the hilo needs shortening aswell.
Thanks
i would just remmove 5mm from the steel threaded male section , this should be enough to allow the car to be lowered sufficiently,
if not you can always remove some from the alloy trumpet ,
carl
Tareq
Member #: 970
Bahrain
Thanks Karl
You cannot run a Mini at Miglia height on the road. Period.
However, if using new cones, you'll need to remove some from the aluminium trumpet as well.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Tareq is not building a roadcar Vegard *wink*
You will need to remove material from the alu part as well Tareq! I have removed loads to be able to get it low enough.
Edited by miniminor63 on 24th Jan, 2011.
t3gav
Member #: 229
Gavin@minispares.com
kent
Some of the migs have the knuckles machined as well i believe. I machined about 5mm off my Hilo's.
