| Home > Non-Mini Discussion > OT Volvo V40 Diesel Woes | |||||||
26th Jan, 2011 at 09:21:18pm
Bit of a long shot, but I hope somebody on here can help with this as there isn't much help coming out of the Volvo community. Basically, bought a 2003 V40 1.9 diesel last week and it quickly became apparent that it was lacking in power and the mpg was lower than the generally accepted norm (43mpg cruising at 70, instead over 50mpg). This is a Renault common rail diesel lump running at 115bhp. Common fault on these is a blocked EGR valve, and I removed mine and cleaned it up (it was chocka with oily sludge) but it made no difference. Air filter is like new, changed fuel filter which made no difference.
27th Jan, 2011 at 07:24:41pm
best to BLOCK the EGR mate, they only lead to trouble.
27th Jan, 2011 at 09:10:45pm
You are right that variable vein turbos don't have wastegates, but they do have actuators to change the vein positions.
http://www.twin-turbo.co.uk
27th Jan, 2011 at 09:56:19pm
You got me thinking evolution, so I went out for a drive with my cheapo OBD and laptop. You are right, it was boosting its arse off. Couple of graphs for comparison, the first one is with the boost solenoid connected properly (but possibly not working correctly), and the second one is with the third port blocked off. Any thought about the boost curve on the first one? I think my first port of call is to check all the vacuum hoses and then get a boost solenoid from the scrappers to try out.
27th Jan, 2011 at 10:06:03pm
I would give your solenoid valve a good clean out first, it takes hardly any gunk at all to restrict the amount they can bleed off or flow.
27th Jan, 2011 at 11:16:24pm
hmm :S your average diesel runs 15-20psi of boost, thats 30-35psi absolute so not totally out of the quesiton, assuming your obd readout is accurate!
Edited by evolotion on 27th Jan, 2011. turbo 16v k-series 11.9@118.9 :)
1 Posts Member #: 11425 Junior Member |
10th Aug, 2016 at 02:39:40pm
Hi metroturbo.
10th Aug, 2016 at 05:24:53pm
The car has long since gone, and I'm afraid I've no idea what OBD reader I used. What I can tell you is that the fault was with the boost solenoid being stuck open. Fitting a new solenoid fixed it straight away. |
