Home > Help Needed / General Tech Chat > clutch time....one thing after another
1275_dan
Member #: 441
got me motor on the road again last night after one of the gears giving up, its a 1275 turbo with s/c gears and drops,4 pin diff,running around 6psi *oh well*
drove off tonight and when coming on boost the revs went right up without the speed changing....and it smelt like burnt clutch...
after abit more driving around it wasnt doing it,but when giving it some i can smell that burning aroma again...*indifferent*
so guessing im in need of a new clutch kit?? what would you recomend and how much we talking? worty changing to a lihtened flywheel aswell??
could this be down to the s/c gears getting more power down??
as it were fine before i changed the gears *tired*
cheers
ps. car is pushing out 98bhp
evolotion
Member #: 83
Glasgow, Scotland
clutch ajustment?
Denis O'Brien.
Doodmeister
Member #: 149
Alberta, Canada
What setup you running now ?? Grey Dia with a Rally plate ? or is it the std setup.
1275_dan
Member #: 441
totally standard setup, soon as turbo comes in revs go right up and it slips like a bitch. so its defo gone
what one do i need??
cheers
if the clutch is standard
i bet its just given up on you as you may be driving a little spirited now
with it all back together if you have done this correctley?
hope so
if you fit a lightend flywheel i strongley suggest you have all the rotating components ballanced
and this means the engine out
if you just fit lightend flywheel sure it will work! But...............
i know the engine will not feel smooth when running anymore also further down the line you will have problems
the standard vertro cluthch is capable of taking more power than people give it credit for say 120bhp ish
the majority of all the problems on this site ARE....................
cause by most people getting hold of a standard metro turbo unit which is now older than my Granny and firing that in
and go whacking the boost up etc etc and the engines 80% clapped......out
its done more miles than a starship
they just keep going back over the weak links worn out parts
Dan in your case, Now
now that you have it all back together i would fit a new standard clutch and leave it at that i think you will be happy
*happy*some may argue................... but thats my oppinion *wink*
Edited by BENROSS on 11th Mar, 2005.
Have you nipped the primary gear seal when you built the engine back up and so is it leaking oil onto the clutch?? Did you use a new primary gear seal??
1275_dan
Member #: 441
Yeah has been done properly,but yeah i know nothing of the engines history and it has been chucked in there,and boost cranked up. ive got a genuine turbo clutch kit now,should be more than ok for standard ish setup.
the clutch wasnt slipping all the time though, but when it wernt slipping you could still smell it.so im guessing the clutch is fooked and theres no oil leakage.. we shall see
i dont mean to be a pain it the rear dan
but thats about the size if it buddy
determanation persistence and a good intrest in these....
super minis is what we have ALL got *happy**happy*
and you cant ask better than that buddy*happy*
go for it dan and do the above!
Has it really been done properly?? Are all the straps straight, is the clutch diaphragm flattened??
Read this:
http://members.tripod.com/%7Emini_digest/clutch.htm
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89<br> Supercharging minis since '04
if its standard turbo then its a verto clutch ,
you can
a,change for another turbo clutch kit after checking the one thats in it (should relase at 90 kg )
b, fit an uprated one -i do a 110 kg clutch i would rate it for 130 bhp
c, change to mini type clutch unit and decide what power you will be getting in the future for plate and cover choices which takes you up to the strongest for 200 bhp -thrust bearings beware -
then decide whether to lighten/balance what you have if necessary
Edited by stuart gurr - vmaxscart on 11th Mar, 2005.
i did not no you did the uprated vertro stuart
nice to know
thanx
1275_dan
Member #: 441
got it off and theres no leaks,clutch isnt dead but you can smell its been slipping, could this be down to the pressure plate or something???
ganna change it anyways
Member #: 350
probably tired pressure plate
1275_dan
Member #: 441
Yeah thats what i thought,as it didnt slip all the time,oh well got another one now so should see to that..
one more thing,my car didnt seem as quick when i changed the gears,dya rekon its coz the clutch was slipping slightly??
Probably, keep an eye on the Debris in the oil with your new box Dan.
May warrant a oil, filter change in a few hundred miles *wink*
1275_dan
Member #: 441
yeah i gave the box a real clean out,changed filter and put some 15/50 oil in there,
so theres a good chance the clutch could of been reducing the power then?
possibley dan having said that................
you now have straight cut gears and these are renound for more friction especially when NEW!
*wink*
1275_dan
Member #: 441
hmm would make sense,il let you know how it goes.
cheers for thr help once again guys *happy*
