Home > Technical Chat > Turbo SU Carb tuning
carl talbot
Member #: 1323
I have no experience with the SU carb for forced induction .
I see the same carb , HIF44 , used for various engine capacities , from 850 to the 2L Montego engine .
Is there much internal changes [ spring + needle ]
Is there a different size main jet fitted
Thanks
Carl
Ben H
Member #: 184
Melton Mowbray, Pie Country
Here is a great guide on tuning SU carbs
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159683
http://www.twin-turbo.co.uk
carl talbot
Member #: 1323
Cheers for the pointer Ben -
I must be rubbish at using the search feature - missed that one completely !
So to clarify - is there only one mainjet size for these carbs and tune by needle , even for different capacity engines ?
I'm looking at a supercharged 1200cc
p.s I need to get a carb and dont want to end up with a Montego one if it isnt going to be any use
Edited by carl talbot on 30th Jan, 2011.
Any carb will be of use. More importantly are you blow through or suck through ?
metroturbo
Member #: 989
North Yorkshire
The montego carb comes with an auto choke that you would have to convert to manual, so it is best avoided unless it is a bargain.
Matt Wood's runs 300bhp on a turbo hif44, so one should be more than man enough for your application.
carl talbot
Member #: 1323
its going to be blow through ,
Thats good info re Montego , to avoid auto choke.
Im not worried if its 'man enough' more the opposite !
