| Home > General Chat > Avon CR500 Tyres | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
31st Jan, 2011 at 01:40:38pm
Has anyone used these Avon CR500 175/55/13 tyres im looking them as an alternitive to the a048s as they are 80-90% as good in the dry but are also very good in the wet acording to the caterham guys.
"Tuning should be a compromise between what is possible and what is necessary"
31st Jan, 2011 at 05:36:39pm
Are they not 185?? If so then i think the don uses them, not 100%sure but i have seen it using avon tyres before Drives
31st Jan, 2011 at 05:38:12pm
They do 185s and 175s "Tuning should be a compromise between what is possible and what is necessary"
31st Jan, 2011 at 05:48:06pm
They are wank, or at least that is what we found with the ones on the DON. They were sold as not very old but I think they are ancient, as they are rock hard.
31st Jan, 2011 at 08:38:49pm
The tyres on the Don, are ACB 10s , not CR 500,.
31st Jan, 2011 at 08:47:29pm
Be interesting if anyone has used them I use the car in the wet and the dry so was looking for an alternative. "Tuning should be a compromise between what is possible and what is necessary"
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
31st Jan, 2011 at 10:09:11pm
I'd just go for A539's if you're using them in the wet as well. Never had an issue with mine. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
31st Jan, 2011 at 10:16:37pm
I found the contisports pretty good,
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
1st Feb, 2011 at 08:50:27am
There Maxxis MAZ-1 Victras if anyone wanted to read up on them. I've got a set on my daily driver (albeit 235/35/19) and not had any issues with them. Not as good as the contisports but they were less than half the price in the above size.
On 31st Jan, 2011 Joe C said:
I found the contisports pretty good, there is a new maxis out that might be worth a punt, http://cgi.ebay.co.uk/MINI-175-50-X-13-SPO...=item51974c6756 |
1st Feb, 2011 at 11:57:15am
i like the tread pattern on them maxxis
