Home > Technical Chat > EN24 driveshafts
tadge44
Member #: 2500
Buckinghamshire
Bit off the topic of Minis but I have just splashed out on a pair of EN24 half shafts for the rear axle of the turbo A35.
I notice that where they are reduced slightly in diameter just before the splined section which enters the diff, the step is quite abrupt between the two diameters.
My limited understanding is that this could create a notch effect so that failure is likely to occur at that point.
I am proposing to smooth out this step, spreading the change of section over say 25mm, Does anyone think this will have any beneficial effect ?
Lastly, is tufftriding the shaft a good idea, to add strength ?.
are vyou saying the shafts are plain old en24, i would have thought they needed to be case hardedned in some way or another at least,
carl
tadge44
Member #: 2500
Buckinghamshire
Not sure if they are case hardened -will go out tomorrow and see, but I would guess that only the splines will be hardened.
Just found out someone else is making them from EN30 and hardening them - at the same price I paid !!
Any thoughts for me on the notch effect idea ?. Or the tufftriding ?.
i reckon it depends how sharp the change is, if theres a radius i wouldnt worry overly,
I thought tufftridings main benifit was from a wear point of view, anyone?
how about cryo treatment?
longy
Member #: 2727
Bicester
heat treating it to the specification below should be sufficient, if it hasn't been already.
http://www.westyorkssteel.com/EN24.html
what diameter is the notched section and whats the max engine torque?
Edited by longy on 1st Feb, 2011.
1972 998 TURBO SLEEPER
tadge44
Member #: 2500
Buckinghamshire
I have determined that they are heat treated but have not been able to establish to what level.
The shaft is 26mm in diameter and the reduction is 0.5mm,not much, but there is no appreciable radius. The producer says they never break here, only on the splines !
As to the max torque its a 1275 engine with a Turbophil head,MG NA cam and will be running a GT1752 at 15psi min
Megajolt (natch) and gas flowed exhaust manifold - one RC40 silencer on a 52mm exhaust, so whats the best guess ? I am hoping to match the Metro van at 150+bhp and how much torque ?.
Match for how much longer though Dave? Changes are a foot *wink*
Think we currently have a guestimated 170 curlly wurlys
With that spec I think you will absolutely muller our metrovan power-wise dave.
I'm going for AT LEAST 160curlywurlies at 15psi
longy
Member #: 2727
Bicester
im working on a shaft at the moment that made from EN19 hardened, with an maximum OD of 30mm and thats running 500Nm, so im sure this notch will have no effect
longy
Member #: 2727
Bicester
you got me !!!
From a strict engineering point of view a generous radius is required to improve fatigue life (just like crankshafts).
Notches or sharp corners just aren't acceptable in anything subject to fatigue (alternate, reversed loadings like a crankshaft).
But if they are absoulutely perfectly machined concentric the only fatigue loading will be torque - most drive shafts suffer fatigue failure from bending loads because they are never perfectly concentric or straight (I could quote one classic example from my industry...)
But if the supplier isn't too worried about leaving a sharp corner he may not be too concerned with it being concentric/straight.
tadge44
Member #: 2500
Buckinghamshire
Thanks everyone, once again my background knowledge has been increased.
I will try to improve the "step" and polish it out and then we will see how much abuse they can take.
Point taken Andy, I will always be one step behind, but I think I will have to accept that I can only go so far
I don't think you will be behind. Your new spec sounds very close to what we are aiming for.
Not at all. I think we should be a pretty close match this year. I reckon you could push 200 bananas if you wanted to.
Regardless of speed, the A35 will always look nicer than the only metro van in the world...... *wink*
^^^ Agreed!
tadge44
Member #: 2500
Buckinghamshire
Aw shucks guys you are making me embarassed
steve1275
Member #: 951
Bromsgrove
Hi David,just seen this,I think the reasoning is that undercut splines produce stress raisers and relieving the shaft so that they are proud reduces this.It's a well known mod amongst the midget racers (little fast people) :cool:
'Where does the engine go?'
On 4th Feb, 2011 steve1275 said:
relieving the shaft so that they are proud reduces this.It's well known amongst the midget racers
What the midget racers get up to in private sounds rather concerning*happy*
Edited by minimole23 on 4th Feb, 2011.
tadge44
Member #: 2500
Buckinghamshire
As far as I am concerned its all a bit academic now as I have sold them and am having some better(?) ones made in heat treated EN30.
