Home > Technical Chat > One for the Machinists (skilled operator of machine tools) and Engineers
When you machine up an O ring groove what are the dimensions for 1.5 and 2mm.
Also is the groove put in one or both mating surfaces
Groove only goes in one surface, as for size, depends on the section of ring you plan to use.
Tom thats great ta
section would be either 1.5mm or 2mm, ID would be 57mm, for a 1.5mm section i would presume that the groove would be cut say 1.5mm wide but something like 1mm deep so it seals.
Is that sort of right?
Edited by wolfie on 3rd Feb, 2011.
Yes more or less, obviously you need to make sure the ring sits proud of the grooved face to give it some compression.
cool thanks
i am trying to do some drawings but its hard without the correct tech data
http://www.parker.com/literature/ORD%20570...ng_Handbook.pdf
