Home > Show Us Yours! > FAO Luke, SC12 WI and Antistall Dodgy Testing :)
As discussed at Bingley, a pic of the inlet manifold with WI ports and the fitting for the antistall
Shiny
WI port External 1/4 push fit fitting
WI port Internal
Anti-stall port 6mm push fit fitting
Edited by gr4h4m on 11th Feb, 2011.
This for yours Graham ?
Yep mate, Water injection for 2011...
and I like the idea. :)
Bit more boost as well then ? *happy*
998turbomini25
Member #: 2276
sheffield / derby
very nice :) thanks for putting the pics up Graham gives me somthing to think about!!
luke
How does the anti stall work? Are you having issues with it cutting out?
kenny2
Member #: 5362
wexford in ireland
whats the advantage of water injection, sorry for my stupidity,
On 5th Jan, 2011 wolfie said:
Andy500
Member #: 2443
Cheshire
In simple terms it has an intercooling effect hence you can run more boost or higher CR and if mixed with Methanol increases the octane rating. Theres also a few articles which detail its cylinder and head cleaning capability.
A bit of a pikey setup test....
you can just see the mist with the crap cam but it mists nicely
http://s132.photobucket.com/albums/q18/Min...nt=MOV00648.mp4
