Home > General Chat > Part Throttle Lean Off.
So my Sprint has been a bitch to drive for ages. The fuelling has been all over the place and it's had a missfire on cruise.
I've tried lots of things but no change. today in a desperate attemp to find the problem (and thinking that cruise was the worst condition) I blocked the part throttle lean off pipe.
It's like a new car. fuelling spot on, propper boost, lovely jubblie.
And to add the this I found my I-pod while scrabbling around trying to find the screwdrive I keep in the car for tinkering.
Anyone else had issues with the part throttle lean off not working. The link pipe was in perfect condition btw.
Johnny
Member #: 6926
Accrington
my lean off is blocked but its misfiring at cruise, its going down to 11.5 afr and it never used to. so i might connect it back up and see how it goes.
That's why we have a pair of small maul grips in the van's door pocket. Instant part throttle lean of clamp *smiley*
^ Not anymore they are back in my toolbox. I blanked the hoses off before RR day.
Possibly the drilling from plenum to chamber is blocked or something.
BAC! They're mine!
Kean
Member #: 341
aka T2clubby
South Staffs
I had the exact same issue and solution with mine Wil. Nice easy fix for a change
Coupe
Member #: 2178
Leyland, Lancs
Mine would never run right with the part throttle lean off. The moment it was blocked off it ran perfectly.
BAC! They're mine!
Incorrect. I know you own pretty much every set of grips in the northern hemisphere but these ones actually came from my house when I spent the weekend tuning the van pre-avon last year.
its hard to get the mixture spot on using the lean off pipe, with some engine configurations its all but a pain to sort
wintersurferuk
Member #: 2208
mines blocked off but I seem to be going through petrol, does run well but the fuel i go through is silly.
next rr im going to im going to bring a new nedle and try to get it setup with it.
How about adding an aquarium valve inline so the part lean off is adjustable,
I'm thinking a solenoid cvould be added in line so you can get it set up for power with the lean of pipe blocked, then trim it for cruise with the Aquarium valve, you can then switch between blocked and not, perhape even add a throttle switch so when you floor it, it switched the pipe to blocked off.
^ I believe robert has a solenoid on his.
But good thinking Joe! Might be a good way to eek a few more MPG out.
You mean he dosent just push the choke in lol.
If it worked then a solenoid would be a good idea.
metroturbo
Member #: 989
North Yorkshire
If you have megajolt or similar you could easily control the solenoid based on manifold pressure - vacuum open, boost closed.
Really cant see why it's causing problems.
What does it do ? Does it make it go too lean, or rich ?
It goes all over, completly inconsistant AFR. On cruise it just backfires, then fuelling stabilises then does it again.
I agree, how can it mack such a differance. Hence why it took me months to even try blocking it.
mcalvert39
Member #: 442
Manchester
maybe vacuum pulses in the lean off pipe are causing a problem. Or just a sticking valve?
Mines been blocked for ages. Never ran nicely beforehand.
Some sort of control would be good though. My part throttle afr is around 10:1 which is higher than wot.
Edited by theoneeyedlizard on 11th Feb, 2011.
Obviously it's a long time ago. And I had no plenum restrictor.
But I never had any issues, and I always had the lean pipe installed. That said, there were no such thing as widebands back then, so n idea what AFR's were actually like.
But it wasnt particularly hard on fuel or anything.
I guess whether it is installed or not hardly matters as long as the end result is the car diving nicely.
But for the above post saying he is seeing 10.0:1 AFR on cruise, that is ridiculous. That is a major problem that needs sorting. Whether by lean off pipe or a proper needle to suit.
T3Tone
Member #: 252
Sunny suffolk
Really seems to differ alot with different configurations, some have fueling troubles where it lean off pipe needs optimising or removing, others (myself included) dont have any trouble with it. Tested mine on the rollers did not make any difference weather it was blocked or not.
-MINI CLUBMAN 1380 TURBO-
Well I have had 4 turbo engines so far and this is the only one that I've had issues with.
I'd rather run it, but it is obviously not right. When I have time I'll whip the carb off and have a nosey.
T3Tone
Member #: 252
Sunny suffolk
You could try putting a restrictor in the lean off pipe, as per turbo phils site......
http://www.turbo-mini.com/9764/index.html
