| Home > Help Needed / General Tech Chat > can centre oil pickup pipe be fitted? | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
13th Feb, 2011 at 09:03:10pm
i will soon be replacing the gearbox for one thats all ready built up but if has the standard pickup, can i replace this with a centre pickup whilst the box is all together?
13th Feb, 2011 at 09:07:06pm
You have to lift the laygear out so required a partial stripdown to get it in.
17th Feb, 2011 at 10:12:46pm
I don't know wether or not to not do it just yet. I have the gearbox built up. I will be putting the engne on it and changing the diff but I have never done anything with the gear box other than the diff and don't want to risk breaking something.
![]() 825 Posts Member #: 2208 Post Whore Essex |
17th Feb, 2011 at 11:19:33pm
you cant fit it without one, you'll lose oil pressure for sure. |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
17th Feb, 2011 at 11:49:25pm
i would just do it now, youll only regrett not doing it when its all in. Edited by Rick.SPI on 17th Feb, 2011. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
18th Feb, 2011 at 08:05:56am
It's easy enough, it's only nuts and bolts and a shaft to slide out. Get a metro haines manual, they have full stripdown and rebuild instructions for gear boxes On 11th Feb, 2015 robert said:
18th Feb, 2011 at 01:52:31pm
john is spot on here. get a metro heynes manual, it wont take you long to do at all. |
18th Feb, 2011 at 02:27:04pm
no no no. I'm Andy, John is the short chubby lad with the spec's On 11th Feb, 2015 robert said:
18th Feb, 2011 at 02:52:29pm
Yeah Andy is the tall lanky git with the big nose. If something is worth doing, it's worth doing half of. |
21st Feb, 2011 at 01:56:16pm
Ok then I will give it a go, I have since decided to get s/c drops is it hard to fit the bottom one - what's it's real name? I know the idler And the 'top' one.
21st Feb, 2011 at 02:03:05pm
21st Feb, 2011 at 02:10:01pm
Just orderd metro Haynes from eBay. I have yet to take the engine out so got plenty to do for now.
21st Feb, 2011 at 03:25:37pm
If you are changing the diff ratio you will have to lock up the box to get the main pinion nut off, so at the same time you can take the nut off the first motion shaft at the other end to replace the bottom transfer gear. I would call it the input gear but each to their own.
21st Feb, 2011 at 08:15:09pm
I'm not changing the ratios Tom. The box is built up Allready though it is pretty much brand new with only about 2 months usage on it. It is standard so I want to add the oil pickup. X-pin diff and the straight cut drops. Then next year the engine will be rebuilt. It has a short FD in at the moment though I don't know what it is I will count the teeth when I remove it. It felt a lot nicer than the one that I used after that on a different engine.
21st Feb, 2011 at 08:23:15pm
We're running a standard box with cross pin diff and s/c drops at 150 bananas on the metro van. I'll be splitting it of the block tomorrow to see how well it has survived. It would be fair to say it's been abused ever since it was fitted, but it certainly drove OK before it came out. On 11th Feb, 2015 robert said:
21st Feb, 2011 at 08:35:07pm
That's brilliant news for me Andy I look forward to seeing how it did as I want somewhere in the region of 150 but only next year after the engine is rebuilt. The gearbox by that time will have another 6 months road use with only a but of track use if I manage any at all. |
23rd Feb, 2011 at 08:06:20am
My manual came well quick from eBay! It was at home waiting for me when I got home from work yesterday. Will have a look at it today.
23rd Feb, 2011 at 08:14:24am
I'm working in Rotherham today with not much actual work on if anyone is in the garage and fancies a bit of a chat? |
23rd Feb, 2011 at 08:21:47am
Couldn't shift the flywheel. Left it torqued up over night. I'm in work near Bradford...
23rd Feb, 2011 at 08:31:22am
I might be back here again it's a big job that I'm on so will be on for a while. But Im not sure what days.
23rd Feb, 2011 at 09:33:28am
2-3000 miles, it's only being replaced as we'ev got a s/c gear set On 11th Feb, 2015 robert said:
