| Home > Show Us Yours! > TB\'s for the 7 port! | |||||||
![]() 141 Posts Member #: 7891 Advanced Member Annapolis, MD USA |
17th Feb, 2011 at 01:27:27pm
Big thanks to JohnK and the guys at Specialist Components! Just got my DCOE throttle body setup for the Pierce/MED 7 port head. Looking forward to starting the install process in the next few weeks....setup included AT throttle bodies, pico injectors, air filter assembly, typhoon ecu, harness, associated sensors, coil pack w/wires, fuel regulator, etc.....
Eric
17th Feb, 2011 at 01:28:51pm
Noice! If something is worth doing, it's worth doing half of. |
17th Feb, 2011 at 01:32:19pm
very nice. On 11th Feb, 2015 robert said:
17th Feb, 2011 at 01:40:21pm
How you going to get that water temp sensor in the hole? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
17th Feb, 2011 at 01:48:32pm
Very nice, looks lovely! |
17th Feb, 2011 at 01:57:56pm
Room for longer bellmouths in the america? If something is worth doing, it's worth doing half of. |
17th Feb, 2011 at 02:02:15pm
wil_h...it was suggested to tap the thermostat housing for the water sensor.
Eric
17th Feb, 2011 at 02:13:27pm
I only ask because I have the same sensor and the same hole issue.
17th Feb, 2011 at 02:51:49pm
On 17th Feb, 2011 wil_h said:
I was thinking of using an SPi sensor that screws straight in then put another sensor for the gauge where the heter tap would usually be. Good plan! consider it stolen! On 11th Feb, 2015 robert said:
17th Feb, 2011 at 03:02:34pm
17th Feb, 2011 at 03:19:24pm
I like the idea of tapping the heater block off as I just have a plate on mine...not sure if my loom is long enough though as I think most of the sensors are wired up to be on the front of the block. Eric
17th Feb, 2011 at 03:23:03pm
Yes I had the same problem with loom lenghts, hence if you buy the SPi sensor it all fits.
17th Feb, 2011 at 03:38:33pm
Any thoughts on the actual placement going from radiator side of thermostat to the actual head? Not sure how the temps may vary from one to the other, but wondering if if is hotter in the head and how that could affect the ecu...probably not much difference where the original temp sensor is, but what about on the opposite side of the head where the heater take-off is? I guess I could always check with the infra red meter for a quick external reference. Eric
17th Feb, 2011 at 10:53:44pm
Did you say 'spare' 7 port head?.. In the 13's at last!.. Just |
![]() 825 Posts Member #: 2208 Post Whore Essex |
17th Feb, 2011 at 11:16:10pm
i thought that!
On 17th Feb, 2011 theoneeyedlizard said:
Did you say 'spare' 7 port head?.. |
18th Feb, 2011 at 03:36:58am
Did you say 'spare' 7 port head?.. Yeah....the one in the pic is an early casting directly from Pierce with the standard valves and larger spark plug. The one on the car now is the MED Rally version that is ported with a larger intake valve and 8mm spark plug....Mike Pierce said he revised the casting for the smaller plug to allow for skimming to bring up compression if desired. Eric
18th Feb, 2011 at 11:00:41am
On 17th Feb, 2011 EricsAmerica said:
wil_h...it was suggested to tap the thermostat housing for the water sensor. I think I've got a couple of thermostat housings WITH metal for the temp take off. if of interest, I'll have a look. On 13th Jul, 2012 Ben H said:
