Home > General Chat > oil pressure fail, opinions please?
eden7842
Member #: 8852
leicestershire
hey
my mate drove his mini 25 miles to go on the rollers on sat and a few miles away he lost oil pressure suddenly. he said it then came up too 5psi a couple times breaifly.
just want to know what its most likely to be, its a standard metro turbo lump.
cheers eden
stuck releif valve maybe
adcyork
Member #: 6807
York
Oil pump or bearing failure potentially, either way, having run the engine with no oil pressure for any length of time there's a good chance that some bearing damage will have been caused now.
eden7842
Member #: 8852
leicestershire
the prv is ok and he only ran it the last couple miles with it low. would a failed bearing cause it to come back breaifly?
Nick
Member #: 154
Midlands
i'd check it with a different gauge first
eden7842
Member #: 8852
leicestershire
he does have a tim gauge
did the pressure light come on?
I'd check the gauge first to rule this out; As Carl suggested then the PRV.
After that, if low oil pressure is diagnosed, I'd be pulling it apart for an inspection.
if you have checked the RV properly!
with the oil pressure dropped it may have stuck open then the debris may have been dislodged, shutting the valve, there may be worn bearings now ?
i would try another gauge as suggested to make sure
if not look see if the RV in the oil filter head is stuck open but i doubt it
next is worn mains bearings
I've had the little ballbearing valve in the oil filter housing stick open and cause a loss of pressure. worth a check.
maybe a good reason to check with another gauge lol
Has he physically removed the PRV and checked spring and plunger are working and nothing seized ?
eden7842
Member #: 8852
leicestershire
he was at shoutham mini centre and they checked the prv and the gauge
Could be as simple as a damaged oil pump gasket. If everything has been checked and a decent gauge varyfies no oil pressure, its time to start taking the engine apart to look for the cause
I'll say it again incase no-one heard. It has the same effect as the PRV on oil pressure.
Is that no just a bypass vale though will? where does the oil go for it to loose pressure?
Yep.
It does seem odd, but my car would not make any oil pressure when it stuck open.
eden7842
Member #: 8852
leicestershire
yeah thanks wil h. He was going to have a look at that
