Home > Help Needed / General Tech Chat > CR calculations, does this look right?
eden7842
Member #: 8852
leicestershire
just worked out my CR and it came out at 7.2
25cc head
3.8 gasket
18 dish
.8 ring land
4 piston deck to block
on a 1293 engine
does this look right, i intend on running 20psi
cheers eden
I make it 7.29, far too low.
T3Tone
Member #: 252
Sunny suffolk
I came up with 7.26.
-MINI CLUBMAN 1380 TURBO-
Yep, that's a bit low.
I think I ended up with around 20cc in the head to get mine up to 8.6:1. The specs very similar
eden7842
Member #: 8852
leicestershire
yeah i got 7.26 whats the best way to raise it back up?
take the 4cc off the top of the block
edit* you might have to take a chunk off the head too. to bring it back to near standard.
Edited by Sprocket on 21st Feb, 2011.
wez
Member #: 9271
Stoke on Trent
I got 7.26 aswell, so at least I know I can work out my cr right in the future.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
eden7842
Member #: 8852
leicestershire
wats the lowest i can go?
It'll work, it'll just be a pig off boost and on boost it won't make quite as much power. 8 to 8.5:1 will be better for 20psi.
eden7842
Member #: 8852
leicestershire
ah ok cheers wil h, il have to have a think were to skim
tadge44
Member #: 2500
Buckinghamshire
Thats encouraging as I reckon I have 8.3:1
20psi here we come !
Ozyris
Member #: 9054
Disneyland Near Paris
and with a CR of 7.6 how much boost you can put? =)
I'd fell happy putting 25psi into it.
bennyy
Member #: 9037
Doncaster, yorkshire
Imo ideal compression ratio is around 8.0:1, capable of 20psi, so that's what I would be aiming for.
On 15th Mar, 2012 wil_h said:
