Home > Help Needed / General Tech Chat > Problem with Verto clutch slipping
Sumfin special
Member #: 677
Buckinghamshire
Hi All
My Verto clutch is slipping when coming on boost in 3rd and 4th gear.
When i first got the car running the clutch was ok, and then i had it rolling roaded and increased the boost to 10 psi etc, and the clutch started to slip on boost in 3rd and 4th. So i thought ok maybe the clutch is worn and the extra bananas were'nt helping so decided to change the clutch and flywheel for the minispares 180mm extra 20% uprated verto clutch and a lightened flywheel.
Noticed whilst doing this that the oil seal behind the flywheel was weeping slightly so changed that as well. Put it all back together and run it down the road just to find it was slipping now and again, until one morning went out in it and it was perfect with no slipping.
This was great for about a couple of saturdays and then i decided to show off giving it full beans in 1st gear from a set of traffic lights and then it is slipping again on boost in 2nd 3rd and 4th so limped back home.
Took it out saturday just gone and it was not slipping when it was cold but after a few miles it started to slip again.
Is this a problem anyone has come across that can be remedied, or am i flogging a dead horse with this verto clutch, and should change to pre-verto?
Matt
Do an RTS conversion to the verto clutch.
Search and the info is there:)
do a search for a thread called clutch t thoughts it has info on doubleing the strength mof 0a0verto
danrock101
Member #: 9277
Nottingham
My verto clutch used to slip in 2nd with only 58bhp at the wheels with a 3.1FDR. Personally I would just run a diaphram clutch, but i know there's lots of people on here that run verto clutches so I wont suggest that *tongue*
Sumfin special
Member #: 677
Buckinghamshire
Cheers i have found the info in the thread, good job i did'nt chuck away the other clutch :)
I will give that a try thanks again!
Ozyris
Member #: 9054
Disneyland Near Paris
but where do you find the RTS diaphram?? =)
Interestingly I have reached the same limit at 12psi on my 998. Just slipps occasionally.
From previous experience one the organic plates are hpt they never recover (until cold). Most of the time mine is ok.
My plan was to try a sintered plate, but I also have all the bits for an RTS conversion.
bennyy
Member #: 9037
Doncaster, yorkshire
sorry to bring back up an old thread, but i have the same problem, slipping in 3rd and 4th, just started doing it this weekend, silly question, how do i know if i have verto or pre-verto?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Verto has a shot arm on the wok and the pre verto has a long arm
bennyy
Member #: 9037
looks like i have a verto clutch, is rts the best way to go for uprated clutch? or is there an off the shelf item that can take 150bhp ish?
I would say RTS for that power or change to pre verto.
bennyy
Member #: 9037
ok, probably be more like 130 but i just want the extra stregnth incase i do go for more power, unsure what to do.
a standard uprated verto will be at the limit with 130 bananas
bennyy
Member #: 9037
Ok thanks andy.
If you can hunt about, there are verto covers that are stronger. But they are just random. Totally random !!!
With a paddle plate some 17 years ago, my verto held 21psi no problem.
The diaphragm springs on it were significantly heavier than other covers though.
I was just lucky to be able to hunt through several and discovered the wide variation.
But the RTS does seem like the best way forward.
