Home > Wanted > Crank & MK3 Shell/Mini
Mattlad
Member #: 1871
Chesterfield, Derbyshire
As subject, Im after a 1275 A+ Crank just for exchange purposes as mine is beond repair, ideally chesterfield/sheffield area so I can collect, but will be interested if someone is prepared to post.
Also a im after a Mk3 Mini/Shell for a project in restorable condition, the one with the 4 bolt top subframe mounts and the extra roof gutter lip, 1969-1976, again quite locally to Chesterfield or if it can be delivered even better! Not bothered if it has a log book or not
Thanks Matt
can't help on the shell but you can buy the lip for the gutter rail if you want to fit it to another shell
Mattlad
Member #: 1871
Nice one, i didn't know that.
Will still be after a shell to rebuild
eden7842
Member #: 8852
leicestershire
hi
my mate has a mk3 for resto with v5, in leicestershire give me a txt on 07584250720 abd i can get you in touch with him.
cheers eden
I have a crank that will need a hefty grind on the main bearings, and a 10 thou on the big ends if its any use to you.
Mattlad
Member #: 1871
Sorry mate, I enquired about it yesterday and the crank needs to be in a good standard condition.
Mk3 shell provisonally bought cheers Eden7842
Matt
