Home > Beginners Tech > turbo Hiff44 carburetor burned insde!?!?!?!
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
hi
I just took of my turbo hiff44 carburetor and it is unusual burned inside! all black!
Last time when it was off the car, was around 7k miles and it was not so burned. I am not sure is it just normal or it is some kind of issue what I should fix???
Some more photos, however used my phone so not really good ones :(
http://s750.photobucket.com/albums/xx141/c...4%20carburator/
what could be the reason of burning inside???
Nothing special!
Have you had problems with it back firing through the carb?
Clubman Ben
Member #: 8909
North Cornwall
Mine was black in the carb, used to back fire when on load on part throttle, adjustment of timing sorted it out.
Edited by Clubman Ben on 27th Feb, 2011.
If in doubt... flat out! The words of a true legend
tadge44
Member #: 2500
Buckinghamshire
Thats nothing to worry about - almost every SU I have stripped looks like that.
chominsh
Member #: 8160
I am not sure! How can fell if it is back firing?? :/
there where problems with it when i drive more than 65mph! it felt that there is no power.
Nothing special!
chominsh
Member #: 8160
ok I will get timing sorted :)
Nothing special!
chominsh
Member #: 8160
Thanks wolfie, :)
still have problems with adding photos *happy*
Nothing special!
Clubman Ben
Member #: 8909
North Cornwall
When it back fires through the carb, it will pop and at the same time jurk the car.
