Home > Technical Chat > Dual Cone Inlet
Following on from yesterdays discussion about the use of dual cone inlets, I've attempted to simulate the effects.
Basically modified the 7 Port NA model to have two 25mm inlets per port before going through a 35mm TB. Total runner length is around 100mm so representative of the commercially available TB systems.
This is the results of the simulation at 6000rpm:
You can see how the dual cone inlet does alter the frequency of the inlet pulses. At around 360 degrees, valve overlap, the inlet pressure is higher, therby promoting higher VE. There is also higher pressure in the inlet at the end of the inlet stroke.
The net improvement in VE is less than 1% on this particular engine, but it could be higher on an engine with a lot more overlap.
jbelanger
Member #: 831
Montreal, Canada
What I was also wondering about this type of inlet was the effect on the laminar flow. The fact that Calver mentions having to lean out the fueling would seem to indicate that there is more air speed over the carb jet.
But that's just speculation coming from very partial knowledge of these subjects.
Jean
http://www.jbperf.com/
I would expect it to alter the velocity profile across the port with a higher peak in the centre. Given that the MED setup places the inner cone very close to the auxilliary venturi, then I would expect that the higher velocity cause higher fuel flow, hence the need to lean it off a bit.
jbelanger
Member #: 831
Montreal, Canada
So would that have an effect on VE which your model would not take into account?
It may well improve the VE and the model would not identify it because of the method that I've had to use to simulate the cones.
Interestingly, the natural frequency of the dual cone should be higher than a single inlet, but it has lowered the frequency at the valve *oh well*
I've just ran the same simulations with a plenum, first with 100mm runners, then 250mm and in both case I've lost power/VE.
Park that idea for now :(
Bah! this was getting intreguing too.
I was getting the lathe ready to make a set up to ...... *oh well*
Well, thinking about it, the plenum must be cancelling out the advantage. Therefore, if we make the plenum bigger the improvement may come back.
I've used something like 1.6 litres plenum volume. What size plenums are you 7 Porters running?
Mine is about 2.2 litres,
Mines the size of an oil tanker ! Lol
Paul have you done a simulation on a standard inlet and plenum on a 1275 turbo?
No, although I baselined the software on a number of known NA builds, then the 998Ti and got very accurate results.
Why do you ask?
I've just modelled it with 100mm runners, dual inlets and a 2.5 litre plenum and it is no better.
The dual cone arrangement seems to work in free air, but not in a plenum.
We need some method of lowering the frequency of the inlet pulses, as you do with longer runners. This will then raise the peaks of the pressure pulses, which, if timed correctly will help VE.
Just wondered how the results from the simulation came out
