Home > Help Needed / General Tech Chat > Distributor Drive Oil Feed Question
A30racer
Member #: 9023
This is slightly off topic, but if you can consider it as helping out an elderly relative....................
I am building an Austin A30 with a 1380 Sprite block with a K1100 head. I was planning to use Megasquirt for injection and ignition, so no dizzy needed. I thought the hole in the block left would make a great crank-case breather with the right baffle to stop the oil escaping!!
My question is how is the dizzy drive lubricated (splash or pressure)? I've looked at the block and can't see any obvious oil hole, so can I just leave this out without losing oil pressure?
Your thoughts would be very much appreciated
Its just splash lubed,
However, mak sure you pull the dizzy drive out as it'll wobble about and hit the crank.
A30racer
Member #: 9023
Thanks Joe,
I thought it looked like there wasn't an oil feed to the drive, you have confirmed my suspicions, so it can be safely removed and left out of the build!! The cam is only there as a jack-shaft to drive the oil-pump (all lobes have been removed already), so this makes life even simpler.
Sound Like an interesting project,
you should get some pics up, do you know our other A30 owner Richard (tadge44)
You mean Dave....
And Dave has an A35 not A30 *wink*
Yeah, it's 5 better
tadge44
Member #: 2500
Buckinghamshire
6 actually.
A30 - 28bhp
A35 - 34bhp
Anyone seen a quarter mile figure for 34 bhp ?.
PaulH
Member #: 2340
Dublin Ireland
The tried to record it once Dave but the Day wasn't long enough pity really would have been nice for the record.
On 17th Feb, 2009 Rob H said:
Whats it weigh dave?
tadge44
Member #: 2500
Buckinghamshire
Far too much !
quick calc if it weighed 825kg's about 25seconds
tadge44
Member #: 2500
Buckinghamshire
I,ve beaten that - but its not 34 bhp either.
A30racer
Member #: 9023
If live long enough to get this little beast finished it would be good to see if Dave's Turbo 35 was quicker than my 16valve NA 30. .....................!
I'll try to stick up some pictures when I've got my camera connected.
tadge44
Member #: 2500
Buckinghamshire
Be good to line them up on the strip one day.
tadge44
Member #: 2500
Buckinghamshire
I, too, am using the distributor hole as a breather, but also looking to hook up to a crankcase evacuation system previously discussed on here, a la Vizard, with breathers from timing cover and rocker cover included.
Pics in due course.
