Home > Show Us Yours! > My First Mini Turbo Projet
evilbutnice
Member #: 9174
colchester essex
The Start.......
evilbutnice
Member #: 9174
colchester essex
more will follow
Looks a good project, you need to fully seam weld that box in rather than spot welding.
wng691s clubby
Member #: 9252
Cleethorpes
looks a good job
Done now needs redoing lol
evilbutnice
Member #: 9174
colchester essex
so i cant leave it spot welded?
its my frist time welding i dont know how to seam weld..
Please don't take this as being negative but,
1- the box needs (good) seam welding as Wolfie says.
2 - Learn the lesson "measure twice, cut once" - That strip you've added along the top of the box just isn't required if the hole had been cut the right size and you would have been welding to a stronger section.
For seam welding, just practice with two overlapping plates - assuming you are using MIG, it's just a balance between current, wire feed speed and how fast you move the torch. If you haven't got any new metal, just sand the paint of the stuff you cut out and practice on that.
evilbutnice
Member #: 9174
colchester essex
kl thanks for the advice rod s
evilbutnice
Member #: 9174
colchester essex
more work done
evilbutnice
Member #: 9174
colchester essex
Coming on nicely, but you need to seem weld the joints around the bulkhead box in the same way you have the other panels. If you have a crash with it like that, the bulkhead will likely collapse and you will end up with the engine where your legs used to be...
evilbutnice
Member #: 9174
colchester essex
Now seam welded tehe.....
haimesyboi
Member #: 5702
Cornwall
Thats better, are you welding gasless?
much better *smiley*
evilbutnice
Member #: 9174
colchester essex
more work done
wng691s clubby
Member #: 9252
Cleethorpes
looks like a good project
Thats definately gasless welding, one tip i do have from learning with one myself, is do a bit, wire brush the scum off, do a bit more and repeat. looks much tidyer when youre doing it and the smog from the flux doesnt conduct electricity too well, it will help much more. But other than that it doesnt look too bad at all :)
evilbutnice
Member #: 9174
colchester essex
cut out the rear archs then seam welded them back up...
Bodge Job
Member #: 953
London
*surprised*
