Home > Help Needed / General Tech Chat > Quick one - Rear brake cylinder thread size
what is the size of the rear brake cylinder threads. I need some banjo bolts sinc the ones for the one piece goodrige hoses seem to have gone missing.
Should be 3/8 UNF.
philc
Member #: 1346
bromsgrove
sorry to bring this up again, but what length do I need including the thread length. thanks
Just thread in a 7/16 headed bolt and mark the thread length, then add the width of the banjo fitting and take a tiny bit off so that the thread doesn't bottom out and cause the banjo to not seal properly
Or maybe a 3/8" bolt...
Well, unless he knows what it looks like or has a die around to check the thread size, 7/16 head is the simplest form of easy identification *tongue*
Oh and obviously make sure it's fine threaded, not course threaded, forgot to add that if UNF didn't give it away.
Edited by Carlzilla on 7th Sep, 2013.
A 7/16 bolt is 1/4 UNF.
3/8 thread bolt is 9/16 AF (across flats).
I'm not going to be much use here but I can't remember which I used. There is a short or a long thread version in the single banjo. I had the same decission to make. I bought both as they were so cheep anyway.
Just get a banjo bolt and cut it down to suit. Run it in without the hose and see where it bottoms out.
Okay my bad, must've confused them, i know one fits haha
