Home > Help Needed / General Tech Chat > sc drops
andyuk1275
Member #: 9276
Darlington north east
quick question.
will any sc drop fit on to a a+ engine or does it need to be certain years etc, is it just the cogs i need to fit them or is other stuff required?
thanks man
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
As long as there a+ all should fit. The pre a+ has a smaller idler gear shaft
and 998 ones are diferent to 1275
Chris Dillow
Member #: 6647
milton keynes
Didn't no that thought they were the same
the primary gear is different, well the rear bush at least,
You can fit A drops in an A+ gear casing with special bearings from Minispares.
http://www.minispares.com/Product.aspx?ty=...id=38305&title=
